Forcing ddns update (using dyndns.com)
joshuaabaxas
My dyndns setup works 99% of the time but on IP change (dialer0) occasionally the update process doesnt work. Hence I'm stuck with the old IP address.
Is there anyway to force an update? Obviously I can reload to fix, but that really isnt a fix!
Thanks in advance
David
paolo bevilacqua
Add the method to a loopback interface, shut / no shut.
