forgot router password...connect with console to pc
malai.joseph
Have a cisco router 1921 ,version 15.0,configuration register is 0x2102
and did not remember the password
try to solve by
GW-RTR>confreg 0x2142
give error    translating "confreg"....domain server (196.46.100.2) (196.46.104.2)
%Bad IP address or host name
%Unknown command or computer name, or unable to find computer address
also tried this
GW-RTR>confreg 0x2102
what are the way forward to get to default settings?
thx
J
2 Accepted Solutions
Jon Marshall
Joseph
You can't do it that way because to change the config-register you need to be in configuration mode ie. enter enable password and then "conf t" but you can't get to config mode because you don't have the enable password.
So you need to do a password recovery, see this doc for how to do this -
1900 ISR password recovery
Jon
Hi Joseph,
By changing the config registery in Romon mode the problem will solve.
Please follow the below procedure which will help you. I did that recently and it worked fine.
http://www.cisco.com/en/US/products/hw/routers/ps221/products_password_recovery09186a0080094773.shtml
Please rate the all helpfull posts.
Naidu.
Jon Marshall
Joseph
Jon
Hi Joseph,
Naidu.
