Forwarding DMZ traffic to DMZ firewall interface in a collapsed network
chase.cameron
I have a question related to forwarding DMZ traffic to the DMZ firewall interface.
I have two layer 3 switches (Nexus 9k) with SVIs that control routing for multiple internal subnets as well as a DMZ subnet. Typically we use separate switches for DMZ infrastructure, but this network is using two nexus switches in hsrp that are acting as both edge, distribution and core (collapsed smaller network).  These multiple internal subnets use a default route statement pointing to the firewall, where their traffic is inspected etc.
The DMZ, obviously, is not part of the internal network and should be ACL'ed by the firewall on its own interface/subinterface. The problem is, I can’t figure out how to tell the nexus l3 switch to forward DMZ traffic to the DMZ interface of the firewall, regardless of whether I use a separate physical firewall interface or a subinterface for the DMZ.
- The default route statement on the switch will forward DMZ traffic to the inside interface of the firewall
- This DMZ traffic will drop once it hits the deny IP any any rule on the inside interface inbound-acl.
- Is it possible to have a statement that forwards traffic from the DMZ SVI (which acts as local DMZ gateway) directly to the DMZ firewall interface, so that the default route is bypassed?
One solution I thought of was to not use SVI's/HSRP for the DMZ and have the firewall be the local DMZ gateway...I’d rather use HSRP if possible since the DMZ is on the same set of Nexus switches as every other routed subnet.
Any advice is appreciated, thanks in advance!
chase.cameron
I figured it out after talking with co-workers...I didn't realize that the firewall can be "vlan aware", and that even if my default route forwards dmz traffic to the inside interface of the firewall, the firewall will forward dmz traffic to the subinterface (with its own inbound-ACL).  As long as the subinterface is called out as belonging to the dmz vlan, then dmz traffic will be forwarded to this interface.  I thought the inside interface would see the dmz traffic and drop it, rather than forwarding dmz traffic to the firewall subinterface.
5 Replies 5
--> This DMZ traffic will drop once it hits the deny IP any any rule on the inside interface inbound-acl
Can you modify the inside inbound ACL to allow traffic to the DMZ ?
This would defeat the purpose of having a separate DMZ interface...I'm trying to get DMZ traffic to the DMZ firewall interface.  I think I figured it out after talking with others locally...they said the default route will send DMZ traffic to my inside interface, but if the firewall is vlan aware, it will separate traffic for processing on its respective interface (dmz in this case).  I just need to enter a vlan configuration for the interface/subinterface.  Does this make sense?
Hello
tbh no - its hard to understand your topology- if you can post a topology then maybe it would become clearer.
Kind Regards
Paul
Hello
why don’t you policy route the traffic you want to hit the dmz  Fw handoff?
Kind Regards
Paul
chase.cameron
