Forwarding of HTTP to two internal HTTP servers
rga-rga-rga
We have Cisco ASA 5505, 90.x.y.2/29 IP is assigned to ourside interface.
We have one internal HTTP server so that I use
static (inside,outside) tcp interface www 172.16.0.10 www netmask 255.255.255.255
to forward all incomming HTTP traffic to internal HTTP server 1.
Now we need to add new physical HTTP server 2 so that I would like to forward
HTTP traffic to e.g. 90.x.y.3/29 to 172.16.0.11.
How can I do that? See scenario image (scenario.png) if needed.
4 Accepted Solutions
wilrow113
you can do this several ways
you could map the internal server to the ip address and allow trafice in on your acl
static (inside,outside) 90.x.y.3 172.16.0.x 255.255.255.255
then an acl on the outside interface in bound for web traffic
Configure the new static as you have the existing static -
static (inside,outside) tcp 90.x.y.3 www 172.16.0.11 www
note that you should still use an acl to limit only http traffic to the address.
Jon
Not sure i follow.
You would need to add -
access-list acl_inbound_outside permit tcp any host 90.x.y.3 object-group og_service_webserver_permit
Jon
you would needed static entrys for the https as well
static (inside,outside) tcp interface https 172.16.0.10 https netmask 255.255.255.255
static (inside,outside) tcp 90.x.y.3 https 172.16.0.11 https netmask 255.255.255.255
and as jon said above at the acl to allow trafic to the servers
6 Replies 6
wilrow113
And best/recommended solution if I want to forward (for security reasons) http/https only?
Jon
Well, I will have this configuration:
interface Vlan2
 nameif outside
 security-level 0
 ip address 90.x.y.2 255.255.255.248
static (inside,outside) tcp 90.x.y.3 www 172.16.0.11 www netmask 255.255.255.255
object-group service og_service_webserver_permit tcp
  description permit HTTP (80/tcp) and HTTPS (443/tcp)
  port-object eq www
  port-object eq https
access-list acl_inbound_outside extended permit tcp any interface outside object-group og_service_webserver_permit
access-group acl_inbound_outside in interface outside
Does acl_inbound_outside apply to second static mapping as well when interface outside is used? Or do I have to add:
access-list acl_inbound_outside extended permit tcp any 90.x.y.3 255.255.255.255 object-group og_service_webserver_permit
as well?
Not sure i follow.
Jon
