FR Mapping confusion in IPV6
Rupesh Kashyap
Hi, I have configured IPV6 on Frame Relay. I am confused where to use "Broadcast" keyword in FR mapping. I mean should I use this in "Link-Local" address or Global Unicast address. Please help.
Giuseppe Larosa
Hello Rupesh,
if you use a dynamic routing protocol like OSPFv3 or EIGRPv6 you need to add the broadcast option to link local mapping because it helps for their multicast hello messages.
see
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-addrg_bsc_con.html#wp1287884
Hope to help
Giuseppe
1. if I use "Broadcast" on Global unicast interface IP and removing on Link-Local, I am still getting all updates.
2. In both cases, I am seeing Next hop as Local link for OSPF update.
Any idea for both queries, why this is happening ?
Hello Rupesh,
this may come from the OSPF network type that influences if multicast are used or not.
sh ipv6 ospf int typex/y
or post the config
2) this is correct: OSPFv3 and EIGRPv6 exchange routing information using link local addresses so it is also reasonable to see the link local as the next-hop ipv6 address
Hope to help
Giuseppe
sounds good.
