Bookmark
Subscribe
3035
Fragment Table Overflow Disconnects Internet
mustafa.chapal
I have a Cisco 3925e router running a IOS Version 15.4(3)M5 and it is being used as an edge router.
The internet stops working and the input rate gets choked on two outbound interface GE0/1 and GE0/2. Whenever this happens I see the following errors in the log:
081425: Nov 24 22:11:11.389 Karachi: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/2: the fragment table has reached its maximum threshold 64
081426: Nov 24 22:11:41.398 Karachi: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/1: the fragment table has reached its maximum threshold 64
081427: Nov 24 22:12:11.407 Karachi: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/1: the fragment table has reached its maximum threshold 64
081428: Nov 24 22:13:15.669 Karachi: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/2: the fragment table has reached its maximum threshold 64
Even after adding this command "ip virtual-reassembly in max-reassemblies 64" on the outbound interfaces, the problem is still there.
Please guide me how to solve this issue.
14 Replies 14
Jose Fonseca
Hello Mustafa,
Please include the configuration for interfaces Gi0/1 and Gi0/2, just to confirm.
That messages is telling you that the maximum amount of datagrams that can be reassembled at any given time has reached the maximum permitted by these interfaces. The default is 16, and that number can be increased up to 1024.
Router(config-if)#ip virtual-reassembly in max-reassemblies ?
 <1-1024>  Number of datagrams that can be reassembled at a time
I will wait for the current configuration just to double check.
Warm regards,
interface GigabitEthernet0/1
ip address x.x.x.x 255.255.255.252
ip access-group inside in
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip verify unicast reverse-path
ip tcp adjust-mss 1460
load-interval 30
duplex auto
speed auto
no cdp enable
no mop enabled
interface GigabitEthernet0/2
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
load-interval 30
duplex auto
speed auto
no cdp enable
no mop enabled
(config)#interface GigabitEthernet0/1
Hello Mustafa,
If we increased the value to the maximum value, the router can use a very high amount of resources trying to reassembly the packets. Please take in consideration the following information:
http://www.cisco.com/c/en/us/td/docs/ios/sec_data_plane/configuration/guide/12_4/sec_data_plane_12_4_book/sec_virt_frag_reassm.pdf
As it mentioned in the file, you need to understand if the reassembly packets are valid, or part of fake packets due to an overflow attack.
I would recommend to increase the value to 128, and turn on the following debug:
debug ip virtual-reassembly
With this, you can confirm if the packets are from valid sources, or in the other hand you can block them to avoid this situation.
Hi Josefon,
I have increased the value to 128.
If the issue still happens and the packets are fake causing an overflow attack, how can I prevent this buffer overflow attack?
You can always block the packets based on the source with an ACL. So you will make sure that fake packets from that particular source, won't cause this issue further.
For instance:
conf t
ip access-list extended fake-packets
deny ip host x.x.x.x any
permit ip any any
If you have different source, you must include them in the ACL, of course.
Please let me know if you have any further questions or concerns. Also and just to confirm 128 value address the issue?
Now the logs are full of the following VFR statuses:
_VFR: Trying to Coalesce in CEF path; pak:0x22BB3B14, Newpak:0x212EB604
IP_VFR: pak incomplete cpak-offset:0, cpak-len:1456, flag: 1
IP_VFR: dgrm incomplete, returning...
IP_VFR: fragment 0x22BB3B14 (sa:180.149.216.9, da:103.44.223.218, id:16342, offset:1456, len:1456) in fast path...
IP_VFR: updated Reinject handle for pak:0x22BB3B14
IP_VFR: Frag 0x22BB3B14 seen in Fast path while processing frag_state
IP_VFR: Pak 0x22BB3B14 has particles; Created newpak 0x2130881C
IP_VFR: Getting hwidb for Pak 0x22BB3B14 in Ingress
IP_VFR: Trying to Coalesce in CEF path; pak:0x22BB3B14, Newpak:0x2130881C
IP_VFR: cpak-offset:0, cpak-len:1456, npak-offset:1456
IP_VFR: pak incomplete cpak-offset:1456, cpak-len:1456, flag: 1
IP_VFR: fragment 0x22BB3B14 (sa:180.149.216.9, da:103.44.223.218, id:16342, offset:2912, len:1093) in fast path...
IP_VFR: Pak 0x22BB3B14 has particles; Created newpak 0x2130399C
IP_VFR: Trying to Coalesce in CEF path; pak:0x22BB3B14, Newpak:0x2130399C
IP_VFR: cpak-offset:1456, cpak-len:1456, npak-offset:2912
IP_VFR: dgrm complete, switching the frags.
IP_VFR: switching fragment (sa:180.149.216.9, da:103.44.223.218, id:16342, offset:0, len:1456)
IP_VFR: Trying to Reinject frag 0x212EB604
IP_VFR: Frag 0x212EB604 hit Ok
IP_VFR: switching fragment (sa:180.149.216.9, da:103.44.223.218, id:16342, offset:1456, len:1456)
IP_VFR: Trying to Reinject frag 0x2130881C
IP_VFR: pak_subblock_free - pak 0x2130881C
IP_VFR: Frag 0x2130881C hit Ok
IP_VFR: switching fragment (sa:180.149.216.9, da:103.44.223.218, id:16342, offset:2912, len:1093)
IP_VFR: Trying to Reinject frag 0x2130399C
IP_VFR: pak_subblock_free - pak 0x2130399C
IP_VFR: Frag 0x2130399C hit Ok
IP_VFR: all fragments have been switched.
IP_VFR: pak_subblock_free - pak 0x212EB604
IP_VFR: deleted frag state for sa:180.149.216.9, da:103.44.223.218, id:16342
IP_VFR: fragment 0x22BB3B14 (sa:180.149.216.9, da:103.44.223.218, id:16346, offset:0, len:1456) in fast path...
IP_VFR: created frag state for pak:0x22BB3B14, sa:180.149.216.9, da:103.44.223.218, id:16346...
IP_VFR: created Reinject handle for pak:0x22BB3B14
IP_VFR: Pak 0x22BB3B14 has particles; Created newpak 0x2132CB0C
IP_VFR: Trying to Coalesce in CEF path; pak:0x22BB3B14, Newpak:0x2132CB0C
IP_VFR: fragment 0x22BB3B14 (sa:180.149.216.9, da:103.44.223.218, id:16346, offset:1456, len:1456) in fast path...
IP_VFR: Pak 0x22BB3B14 has particles; Created newpak 0x213133D4
IP_VFR: Trying to Coalesce in CEF path; pak:0x22BB3B14, Newpak:0x213133D4
IP_VFR: fragment 0x22BB3B14 (sa:180.149.216.9, da:103.44.223.218, id:16346, offset:2912, len:1093) in fast path...
IP_VFR: Pak 0x22BB3B14 has particles; Created newpak 0x212DA82C
IP_VFR: Trying to Coalesce in CEF path; pak:0x22BB3B14, Newpak:0x212DA82C
IP_VFR: switching fragment (sa:180.149.216.9, da:103.44.223.218, id:16346, offset:0, len:1456)
IP_VFR: Trying to Reinject frag 0x2132CB0C
IP_VFR: Frag 0x2132CB0C hit Ok
IP_VFR: switching fragment (sa:180.149.216.9, da:103.44.223.218, id:16346, offset:1456, len:1456)
IP_VFR: Trying to Reinject frag 0x213133D4
IP_VFR: pak_subblock_free - pak 0x213133D4
IP_VFR: Frag 0x213133D4 hit Ok
IP_VFR: switching fragment (sa:180.149.216.9, da:103.44.223.218, id:16346, offset:2912, len:1093)
IP_VFR: Trying to Reinject frag 0x212DA82C
IP_VFR: pak_subblock_free - pak 0x212DA82C
IP_VFR: Frag 0x212DA82C hit Ok
IP_VFR: pak_subblock_free - pak 0x2132CB0C
there is a source and destination IP address in the logs you posted.
Source: 180.149.216.9 --> this is registered to DELTANET-PK (Karachi, Pakistan)
Destination: 103.44.223.218 --> this is registered to CHAPAL (Karachi, Pakistan)
Do these sound familiar ?
Either way, I pinged both addresses, and the lowest MTU at which packets were not fragmented was 1452.
Try and configure 'ip mtu 1452' on both interfaces:
 ip mtu 1452
 ip mtu 1452
The destination is our network. I tested the MTU and I have got the following results:
Sending 32 bytes to 103.44.223.218 <- not fragmented
Sending 750 bytes to 103.44.223.218 <- not fragmented
Sending 1125 bytes to 103.44.223.218 <- not fragmented
Sending 1313 bytes to 103.44.223.218 <- not fragmented
Sending 1407 bytes to 103.44.223.218 <- not fragmented
Sending 1454 bytes to 103.44.223.218 <- not fragmented
Sending 1478 bytes to 103.44.223.218 <- FRAGMENTED!
Sending 1466 bytes to 103.44.223.218 <- not fragmented
Sending 1472 bytes to 103.44.223.218 <- not fragmented
Sending 1475 bytes to 103.44.223.218 <- FRAGMENTED!
Sending 1473 bytes to 103.44.223.218 <- FRAGMENTED!
From the tests we did, we can assume that 1472 bytes is the largest unfragmented packet size. The MTU size would be 1500, made up from 1472 payload and 28 ICMP/IP Headers and payload information.
The maximum MTU size for 103.44.223.218 is: 1500
it probably depends on where you test from. I got 1452. Either way, you wanto to get rid of the log messages, so try 1452 on both interfaces and see what it does.
Using this command ip virtual-reassembly in max-reassemblies 1024 or lowering the MTU did not fix the outside interface choking problem.
Below are the logs after running the command debug ip virtual-assembly
IP_VFR: created Reinject handle for pak:0x22091708
IP_VFR: Frag 0x22091708 seen in Fast path while processing frag_state
IP_VFR: Pak 0x22091708 has particles; Created newpak 0x215BBB70
IP_VFR: Getting hwidb for Pak 0x22091708 in Ingress
IP_VFR: Trying to Coalesce in CEF path; pak:0x22091708, Newpak:0x215BBB70
IP_VFR: pak incomplete cpak-offset:0, cpak-len:1480, flag: 1
IP_VFR: fragment 0x22091708 (sa:63.151.67.235, da:103.76.3.10, id:14820, offset:1480, len:1480) in fast path...
IP_VFR: updated Reinject handle for pak:0x22091708
IP_VFR: Pak 0x22091708 has particles; Created newpak 0x215EE010
IP_VFR: Trying to Coalesce in CEF path; pak:0x22091708, Newpak:0x215EE010
IP_VFR: cpak-offset:0, cpak-len:1480, npak-offset:1480
IP_VFR: pak incomplete cpak-offset:1480, cpak-len:1480, flag: 1
IP_VFR: fragment 0x22091708 (sa:63.151.67.235, da:103.76.3.10, id:14820, offset:2960, len:1040) in fast path...
IP_VFR: Pak 0x22091708 has particles; Created newpak 0x215F50E8
IP_VFR: Trying to Coalesce in CEF path; pak:0x22091708, Newpak:0x215F50E8
IP_VFR: cpak-offset:1480, cpak-len:1480, npak-offset:2960
IP_VFR: switching fragment (sa:63.151.67.235, da:103.76.3.10, id:14820, offset:0, len:1480)
IP_VFR: Trying to Reinject frag 0x215BBB70
IP_VFR: Frag 0x215BBB70 hit Ok
IP_VFR: switching fragment (sa:63.151.67.235, da:103.76.3.10, id:14820, offset:1480, len:1480)
IP_VFR: Trying to Reinject frag 0x215EE010
IP_VFR: pak_subblock_free - pak 0x215EE010
IP_VFR: Frag 0x215EE010 hit Ok
IP_VFR: switching fragment (sa:63.151.67.235, da:103.76.3.10, id:14820, offset:2960, len:1040)
IP_VFR: Trying to Reinject frag 0x215F50E8
IP_VFR: pak_subblock_free - pak 0x215F50E8
IP_VFR: Frag 0x215F50E8 hit Ok
IP_VFR: pak_subblock_free - pak 0x215BBB70
IP_VFR: deleted frag state for sa:63.151.67.235, da:103.76.3.10, id:14820
IP_VFR: fragment 0x22091708 (sa:62.48.185.186, da:103.76.3.10, id:17352, offset:2960, len:1040) in fast path...
IP_VFR: created frag state for pak:0x22091708, sa:62.48.185.186, da:103.76.3.10, id:17352...
IP_VFR: Pak 0x22091708 has particles; Created newpak 0x215C0ED8
IP_VFR: Trying to Coalesce in CEF path; pak:0x22091708, Newpak:0x215C0ED8
IP_VFR: fragment 0x22091708 (sa:62.202.12.3, da:103.76.3.10, id:7580, offset:2944, len:1116) in fast path...
IP_VFR: fragment 0x22091708 (sa:63.231.252.29, da:103.76.3.10, id:31306, offset:1472, len:1472) in fast path...
IP_VFR: fragment 0x22091708 (sa:64.32.122.200, da:103.76.3.10, id:17779, offset:0, len:1472) in fast path...
IP_VFR: fragment 0x22091708 (sa:63.140.119.242, da:103.76.3.10, id:1279, offset:0, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:63.140.119.242, da:103.76.3.10, id:1279, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.176.87.59, da:103.76.3.10, id:49227, offset:2960, len:1040) in fast path...
IP_VFR: fragment 0x22091708 (sa:63.231.252.29, da:103.76.3.10, id:31306, offset:2944, len:1056) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.162.207.9, da:103.76.3.10, id:55673, offset:0, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.162.207.9, da:103.76.3.10, id:55673, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.107.177.73, da:103.76.3.10, id:61438, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.107.177.73, da:103.76.3.10, id:61438, offset:2960, len:1068) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.161.134.85, da:103.76.3.10, id:19274, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.161.134.85, da:103.76.3.10, id:19274, offset:0, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.12.166.219, da:103.76.3.10, id:12405, offset:2944, len:1056) in fast path...
IP_VFR: fragment 0x22091708 (sa:65.183.9.118, da:103.76.3.10, id:27842, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:65.34.233.96, da:103.76.3.10, id:3257, offset:0, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.153.135.57, da:103.76.3.10, id:42684, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:65.34.233.96, da:103.76.3.10, id:3257, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.153.135.57, da:103.76.3.10, id:42684, offset:2960, len:1068) in fast path...
IP_VFR: fragment 0x22091708 (sa:64.17.27.48, da:103.76.3.10, id:12879, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:64.17.27.48, da:103.76.3.10, id:12879, offset:2960, len:1121) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.183.1.244, da:103.76.3.10, id:23171, offset:2960, len:1114) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.210.152.123, da:103.76.3.10, id:31693, offset:0, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.210.152.123, da:103.76.3.10, id:31693, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.210.152.123, da:103.76.3.10, id:31694, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:69.165.131.188, da:103.76.3.10, id:23973, offset:0, len:1472) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.38.131.221, da:103.76.3.10, id:6991, offset:2960, len:1040) in fast path...
IP_VFR: fragment 0x22091708 (sa:69.165.131.188, da:103.76.3.10, id:23973, offset:1472, len:1472) in fast path...
IP_VFR: fragment 0x22091708 (sa:69.165.131.188, da:103.76.3.10, id:23973, offset:2944, len:1056) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.153.201.130, da:103.76.3.10, id:31521, offset:0, len:1480) in fast path...
n:1480)
IP_VFR: Trying to Reinject frag 0x215F3860
IP_VFR: pak_subblock_free - pak 0x215F3860
IP_VFR: Frag 0x215F3860 hit Ok
IP_VFR: switching fragment (sa:61.91.183.154, da:103.76.3.10, id:30055, offset:2960, len:1040)
IP_VFR: Trying to Reinject frag 0x21618520229, da:103.76.3.10, id:29497, offset:1480, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.146.70.229, da:103.76.3.10, id:29497, offset:2960, len:1040) in fast path...
IP_VFR: fragment 0x22091708 (sa:62.146.70.229, da:103.76.3.10, id:29497, offset:0, len:1480) in fast path...
IP_VFR: fragment 0x22091708 (sa:72.143.100.162, da:103.76.3.10, id:26113,
Below is the output of ip cache flow:
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP  Pkts
Gi0/1         83.223.202.222  Null          103.76.3.10     11 0035 7230     1
Gi0/1         85.95.241.132   Gi0/3.203     103.76.3.10     11 0035 4C3B     1
Gi0/3.119     103.44.223.230  Gi0/1         119.254.210.112 11 C5CC 0035     1
Gi0/1         83.31.2.130     Null          103.76.3.10     11 3258 79D7     1
Gi0/1         81.136.227.216  Gi0/3.203     103.76.3.10     11 0035 A36D     1
Gi0/1         83.169.241.46   Gi0/3.203     103.76.3.10     01 0000 0303     1
Gi0/1         81.88.224.79    Null          103.76.3.10     11 0035 D6E3     1
Gi0/1         81.95.255.78    Null          103.76.3.10     11 0035 8A44     1
Gi0/1         84.201.31.138   Gi0/3.203     103.76.3.10     11 0035 8354     1
Gi0/1         82.69.85.65     Null          103.76.3.10     11 0035 C238     1
Gi0/1         83.102.172.103  Gi0/3.203     103.76.3.10     11 0035 499A     1
Gi0/1         85.94.178.198   Null          103.76.3.10     11 0035 ED52     1
Gi0/1         82.119.108.86   Null          103.76.3.10     11 0035 6279     1
Gi0/1         83.211.83.193   Null          103.76.3.10     11 0035 070D     1
The error 'the fragment table has reached its maximum threshold' has been resolved by increasing the value of ip virtual-reassembly in max-reassemblies 128.
But I am still facing this serious problem of the outside interfaces GE0/1 and GE0/2 input rate being congested. During this problem, I see the input and output rate of the inside interface GE0/3 is normal.
Please take a look at the interfaces below during the problem and let me know if anything seems abnormal.
show interfaces
GigabitEthernet0/0 is up, line protocol is up
  Hardware is iGbE, address is xxxx.xxxx.xxxx (bia xxxx.xxxx.xxxx)
  Internet address is x.x.x.x/30
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is ZX
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:19, output 00:00:08, output hang never
  Input queue: 0/75/0/103 (size/max/drops/flushes); Total output drops: 156
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     165465809 packets input, 96241093108 bytes, 0 no buffer
     Received 18457 broadcasts (0 IP multicasts)
     174754 input errors, 0 CRC, 0 frame, 174754 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     68565882 packets output, 33575024181 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 unknown protocol drops
     5 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
     reliability 255/255, txload 1/255, rxload 5/255
  Full Duplex, 1Gbps, media type is RJ45
  Last input 00:00:05, output 00:00:00, output hang never
  Input queue: 0/75/0/214 (size/max/drops/flushes); Total output drops: 531
  30 second input rate 20715000 bits/sec, 6564 packets/sec
  30 second output rate 761000 bits/sec, 771 packets/sec
     889317237 packets input, 129610395025 bytes, 0 no buffer
     Received 232 broadcasts (0 IP multicasts)
     586391384 packets output, 102746524682 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     4 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/2 is up, line protocol is up
     reliability 255/255, txload 1/255, rxload 9/255
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 411
  30 second input rate 38852000 bits/sec, 11030 packets/sec
  30 second output rate 749000 bits/sec, 750 packets/sec
     480446100 packets input, 152092730337 bytes, 0 no buffer
     Received 18030 broadcasts (0 IP multicasts)
     943355 input errors, 0 CRC, 0 frame, 943355 overrun, 0 ignored
     527813427 packets output, 87786740725 bytes, 0 underruns
     2 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/3 is up, line protocol is up
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  output flow-control is XON, input flow-control is XON
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 58586783
  5 minute input rate 4021000 bits/sec, 2915 packets/sec
  5 minute output rate 3882000 bits/sec, 3134 packets/sec
     1208651283 packets input, 244947338943 bytes, 0 no buffer
     Received 36516 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 2276 pause input
     1398699197 packets output, 369932695510 bytes, 0 underruns
     120 unknown protocol drops
try and set the 'ip virtual-reassembly in max-reassemblies' value to the highest possible number, 512 or even 1024, and check if the messages disappear.
Will setting this command 'ip virtual-reassembly in max-reassemblies 1024' have any major performance impact on the router processor or memory?
according to Cisco:
-->Performance Impact
VFR causes a performance impact on the basis of functions such as packet copying, fragment validation, and fragment reorder. This performance impact varies depending on the number of concurrent IP datagrams that are being reassembled<--
The real problem is an MTU mismatch which causes the fragmentation. Try to ping the source of your traffic with the -df bit set, and lower the size until the message 'Packet needs to be fragmented but DF set' disappears:
ping x.x.x.x size 1500 df-bit
