frame-realy traffic shapping
sg_london
Hello.
I though traffic shapping was only "out" of the interface.
In that case why the Cisco Ios is actually giving us the possibility of configuring it as "in" AND "out" under the interface configuration ?
R1(config-map-class)#frame-relay cir ?
<1-45000000> Applied to both Incoming/Outgoing CIR, Bits per second
in Incoming CIR
out Outgoing CIR
mheusing
As a router can also be used as a frame-relay switch, it makes sense to have inbound shaping capabilities.
Router(config)#frame-relay switching
The local or remote switching capabilities are configured with "frame-relay route ..." or "xconnect ..." commands.
Regards, Martin
Thanks !
