FRAME RELAY COMMAND ON 7600
tona_2008
HI,
I need your help. We have a issue with a 7606-S router and frame relay traffic shaping command.
the command frame-relay traffic-shaping is not available, when i want to configure it on a serial interface.
I have the following equipment:
RSP720CXL-R
IOS: ADVANCED ENTERPRISE SERVICES SSH 12.2(33)SRC5
SIP200> SPA-4XT-SERIAL
QUESTIONS:.
DO I NEED TO CHANGE DE IOS SOFTWARE?
DOES 7606-S SUPPORT THIS COMMAND?
DOES SPA-4XT-SERIAL SUPPORT THIS COMMAND?
WHY I CAN'T GET this command on the serial interface?
I KNOW that the flexwan module doesn't support frame relay traffic shaping,
http://www.cisco.com/en/US/partner/products/hw/modules/ps2797/products_data_sheet09186a00801df1d9.html
but, we have SIP-200.
Someone can tell me why i can't get  this command on this serial interface of the 7606 router?
thnks
Reza Sharifi
It does support it, but you need 12.2(18)SXE or later.
Minimum Software Compatibility
Cisco IOS®Software Release 12.2(18)SXE, or later
Here is the data sheet:
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8027c9df.html
Reza
