Frame Relay DLCI 1007 (Active / Unused) ??
gibsthomas
Hey guys
I'm seeing multiple routers connected to Frame-Relay in our network with DLCI 1007 active but unused. We never ordered this DLCI and have not assigned this to any sub-interface. But for multiple sites, its showing up as Active/ Unused under serial interface. Any idea what this DLCI is for?
scottmac
Level 10
Level 10
Assuming you're using a provider's network, you should contact your provider and have them check it out.
It could be a provisioning error, it could be a DLCI available for monitoring services (provider offering a paid service for trap & interface monitoring).
If it's coming from the cloud, the provider should be able to track it down.
If you're running a private "cloud," then it could be a provisioning error on your head-end router(s) or something left over from a previous implementation.
Good Luck
Scott
