Frame-Relay DLCI and Bandwidth
peter.mark
I have two questions regarding Frame-Relay configurations, Point-To-Point.
1. The carrier supplies the DLCI's as follows:
Router A DLCI 100
Router Z DLCI 200
The sub-interface on Router A will be DLCI 200
The sub-interface on Router Z will be DLCI 100
Is this correct?
2. The BW parameter on the sub-interface has no bearing on the circuit. It's there for informational purposes only.
Is this correct?
Pete,
Richard Burts
Pete
Question 1: if the carrier supplies DLCI 100 for the connection on router A then the subinterface configuration must specify DLCI 100 not 200.
The DLCI specified on the subinterface is how the carrier talks to the router not how the router talks to the remote end.
Question 2: correct the bandwidth configured on the subinterface does not change anything about the physical circuit. It is there to describe the capacity of the subinterface to any softwawre that cares (calculation of metrics for EIGRP and OSPF, calculation of load, etc).
Rick
Rick
