frame-relay end-to-end keepalive in a physical interface
idn.wanggang
Dear Sirs:
Frame-relay end-to-end keeplives can be configured in a fr sub-interface,how can we configure in a physical interface?
Best wish
TMBK, the EEK configuration for physical interfaces works the same as for subinterfaces, that is, you define the Frame Relay map-class and then apply it to the (physical) interface. Are you running into a specific problem ?
GP
Hi,GP
Thank you for your reply.
In a subinterface,it works well,but in a physical interface,it does not work.
When one side is shutted down, the other side interface and line protocol still up.
Best Regards.
check if your interface is getting other DLCIs from the Frame Relay cloud, and if so, disable inarp (no frame-relay inverse-arp). Also, try and configure the EEK under the DLCI:
interface Serial0/0
encapsulation frame-relay
frame-relay interface-dlci 102
class EEK
Does that make a difference ?
GP
No.
