Frame Relay interface not able to access
anis_cisco
Hi all,
I have total five routers
HQ, SB, SC
FR
PSTN
HQ Router is physicall connected to FR through Serial Cables (Note: HQ is connected to SB & SC through FR, there is no ip address configured on serial interfaces of FR Router).
FR Router is connected to PSTN Router through fa0/0 interface having IP's 142.250.1.1 - 142.250.1.2.
ospf is configured on all routers with default network
router ospf 1
network 0.0.0.0 0.0.0.0 area 0
From HQ Router i can ping SB, SC Interfaces but from HQ Router i cant ping fa0/0 interface of FR.
when i check the routes on FR through sh ip route ospf i didnt find any routes learned from HQ & when i do the same on HQ, no routes are advertised from FR to HQ
I can see the network information of FR Router into HQ in sh ip ospf interface command & there netwok type is broadcast, which is same in FR & PSTN router .. i dont know why HQ & FR are not advertising route to each other ..
Can any body help here urgent please
Please find the below result from HQ for FR
HQ#
HQ#sh ip ospf interface fa0/1
FastEthernet0/1 is up, line protocol is down
  Internet Address 142.250.1.2/24, Area 0
  Process ID 1, Router ID 1.1.1.1, Network Type BROADCAST, Cost: 1
  Transmit Delay is 1 sec, State DOWN, Priority 1
  No designated router on this network
  No backup designated router on this network
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
HQ#
From FR
FR-Router#sh ip ospf interface
FastEthernet0/0 is up, line protocol is up
  Process ID 1, Router ID 142.250.1.2, Network Type BROADCAST, Cost: 1
  Transmit Delay is 1 sec, State BDR, Priority 1
  Designated Router (ID) 142.250.1.1, Interface address 142.250.1.1
  Backup Designated router (ID) 142.250.1.2, Interface address 142.250.1.2
    Hello due in 00:00:03
  Supports Link-local Signaling (LLS)
  Index 1/1, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 1, maximum is 3
  Last flood scan time is 0 msec, maximum is 4 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 142.250.1.1  (Designated Router)
  Suppress hello for 0 neighbor(s)
FR-Router#
From PSTN
PSTN#sh ip ospf interface
FastEthernet0/1 is up, line protocol is up
  Internet Address 142.250.1.1/24, Area 0
  Process ID 1, Router ID 142.250.1.1, Network Type BROADCAST, Cost: 1
  Transmit Delay is 1 sec, State DR, Priority 1
    Hello due in 00:00:04
  Cisco NSF helper support enabled
  IETF NSF helper support enabled
  Index 3/3, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 0, maximum is 3
    Adjacent with neighbor 142.250.1.2  (Backup Designated Router)
Reza Sharifi
On the HQ router
on the FR router
You assigned the same IP to two different interfaces
change one of them to
Internet Address 142.250.1.3/24, Area 0
Sorry to inform you that int fa0/1 on HQ is not connected into network
Regads,
