Frame relay not working on one of the LANs
JhNG
Hi guys, I've been designing a network where I use frame relay to connect the 3 LANs to each other via the cloud (Internet). 2 of the LANs work just fine they can communicate to each other. But I'm having trouble doing the third LAN which is called "Puchong". I keep getting the "This connection could not be established" error message whenever I try to get the Puchong sublink to connect to other sublinks. The Puchong router has already been configured with ecapsulation frame relay but I have no idea what I have missed. I've tried deleting the router then created a new one but still I get the same thing. Any idea what's wrong with it? I'm so lost now.
on the Puchong router, you need to advertise network 192.168.2.0/24. Attached the revised, working file.
5 Replies 5
Harold Ritter
Hi @JhNG ,
You need to change the FR switch as in the attach image.
You also need to change the config of Puchong, which is currently the same as KL.
Thank you for your reply. I followed and did as the attached images showed. But there's another problem, I can't ping other PCs from all the PCs in Puchong, they all say request timed out.
Also I'm not sure what you meant by the same config as KL router, as I checked but I can't tell if there is any similarities between KL router and Puchong router. I've attached the updated file below. Could you help me correct the issues and let me know what I did wrong?
Thanks again, I appreciate it.
I see. Now it's working, thanks so much for your help!
Does the 192.168.2.0/24 refer to the Fa0/0 on the Puchong router? Just want to be sure as I'm still learning this thing.
Hi @JhNG ,
Yes, you needed to change 192.168.1.1/24 by 192.168.2.1/24 on fa0/0 and you also need to change "network 192.168.1.0" by "network 192.168.2.0" under router eigrp. Also need to change the the se1/0 IP address to 192.168.10.3.
