Frame Relay OSPF nei down Too many retransmissions
mahesh18
Level 6
Level 6
Hi all,
Router 1 is connected back to back serial WIC 1T  to Router 2.
Router 1 is config with frame relay switching command and is acting as DCE.
OSPF is running between them
Router A config
sh run int se1/0
Building configuration...
Current configuration : 175 bytes
interface Serial1/0
ip address 192.168.2.1 255.255.255.0
encapsulation frame-relay
serial restart-delay 0
frame-relay interface-dlci 103
frame-relay intf-type dce
end
Serial int
sh int se1/0
Serial1/0 is up, line protocol is up
  Hardware is DSCC4 with integrated T1 CSU/DSU
  Internet address is 192.168.2.1/24
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
  Encapsulation FRAME-RELAY, loopback not set
  Keepalive set (10 sec)
  Restart-Delay is 0 secs
  LMI enq sent  0, LMI stat recvd 0, LMI upd recvd 0
  LMI enq recvd 4146, LMI stat sent  4146, LMI upd sent  0, DCE LMI up
  LMI DLCI 1023  LMI type is CISCO  frame relay DCE
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 30/0, interface broadcasts 0
  Last input 00:00:01, output 00:00:04, output hang never
  Last clearing of "show interface" counters 11:48:32
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
     7711 packets input, 348717 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     290 input errors, 272 CRC, 18 frame, 0 overrun, 0 ignored, 0 abort**********************************************************Input and CRC  errors
     6275 packets output, 240861 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
Logs
Jan  3 05:59:00.324 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Jan  3 05:59:00.324 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from FULL to DOWN, Neighbor Down: Interface down or detached
Jan  3 05:59:20.358 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Jan  3 06:02:20.669 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from LOADING to FULL, Loading Done
Jan  3 06:23:00.943 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Jan  3 06:23:00.943 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from FULL to DOWN, Neighbor Down: Interface down or detached
Jan  3 06:23:20.976 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Jan  3 06:26:31.305 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from LOADING to FULL, Loading Done
Jan  3 08:44:51.632 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Jan  3 08:44:51.632 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from FULL to DOWN, Neighbor Down: Interface down or detached
Jan  3 08:45:11.669 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Jan  3 08:48:32.010 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from LOADING to FULL, Loading Done
Jan  3 09:44:15.312 MST: %SSH-4-SSH2_UNEXPECTED_MSG: Unexpected message type has arrived. Terminating the connection
Jan  3 09:53:41.457 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
Jan  3 09:53:41.457 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from FULL to DOWN, Neighbor Down: Interface down or detached
Jan  3 09:54:01.678 MST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Jan  3 09:57:06.962 MST: %OSPF-5-ADJCHG: Process 1, Nbr 192.168.8.3 on Serial1/0 from LOADING to FULL, Loading Done
Router 2 config
     sh run int se0/1
Current configuration : 184 bytes
interface Serial0/1
ip address 192.168.2.2 255.255.255.0
end
Serial interface
sh int se0/1
Serial0/1 is up, line protocol is up
  Hardware is PQUICC with Fractional T1 CSU/DSU
  Internet address is 192.168.2.2/24
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  LMI enq sent  4220, LMI stat recvd 4115, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 1023  LMI type is CISCO  frame relay DTE
  Broadcast queue 0/64, broadcasts sent/dropped 34/0, interface broadcasts 0
  Last input 00:00:08, output 00:00:08, output hang never
  Last clearing of "show interface" counters 11:43:20
     Available Bandwidth 1158 kilobits/sec
     6217 packets input, 237778 bytes, 0 no buffer
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     7618 packets output, 343965 bytes, 0 underruns
Logs of Router 2
Jan  3 06:00:31.167 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from FULL to DOWN, Neighbor Down: Too many retransmissions
.Jan  3 06:01:31.072 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from DOWN to DOWN, Neighbor Down: Ignore timer expired
.Jan  3 06:01:31.508 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from LOADING to FULL, Loading Done
.Jan  3 06:24:27.381 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from FULL to DOWN, Neighbor Down: Too many retransmissions
.Jan  3 06:25:27.286 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from DOWN to DOWN, Neighbor Down: Ignore timer expired
.Jan  3 06:25:39.227 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from LOADING to FULL, Loading Done
.Jan  3 08:46:05.466 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from FULL to DOWN, Neighbor Down: Too many retransmissions
.Jan  3 08:47:05.372 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from DOWN to DOWN, Neighbor Down: Ignore timer expired
.Jan  3 08:47:25.828 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from LOADING to FULL, Loading Done
.Jan  3 09:54:27.711 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from FULL to DOWN, Neighbor Down: Too many retransmissions
.Jan  3 09:55:27.617 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from DOWN to DOWN, Neighbor Down: Ignore timer expired
.Jan  3 09:55:29.529 MST: %OSPF-4-NONEIGHBOR: Received database description from unknown neighbor 4.4.4.4
.Jan  3 09:55:34.545 MST: %OSPF-4-NONEIGHBOR: Received database description from unknown neighbor 4.4.4.4
.Jan  3 09:55:39.537 MST: %OSPF-4-NONEIGHBOR: Received database description from unknown neighbor 4.4.4.4
.Jan  3 09:55:44.529 MST: %OSPF-4-NONEIGHBOR: Received database description from unknown neighbor 4.4.4.4
.Jan  3 09:55:54.505 MST: %OSPF-5-ADJCHG: Process 1, Nbr 4.4.4.4 on Serial0/1 from LOADING to FULL, Loading Done
OSPF nei
sh ip ospf nei
Neighbor ID     Pri   State           Dead Time   Address         Interface
4.4.4.4           1   FULL/BDR        00:01:41    192.168.2.1     Serial0/1
My question is why OSPF nei is getting down so frequently and CRC, Input errors are on Router 1?
MAhesh
13 Replies 13
andrew.prince
Level 10
Level 10
Set the clock rate on the dce end and post the output of sh frame map and sh frame PVC And post your OSPF config of both devices
Hi Andrew
Here is required info
Router 1
2691Router#sh frame-relay map
Serial0/0 (up): ip 192.168.1.2 dlci 102(0x66,0x1860), static,
              broadcast,
              CISCO
Serial1/0 (up): ip 192.168.2.2 dlci 103(0x67,0x1870), dynamic,
              broadcast,, status defined, active
2691Router#sh frame-relay pvc 103
PVC Statistics for interface Serial1/0 (Frame Relay DCE)
DLCI = 103, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial1/0
  input pkts 6171          output pkts 4987         in bytes 516641
  out bytes 436517         dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 83        out bcast bytes 2822
  pvc create time 3d13h, last time pvc status changed 06:45:30
router ospf 1
router-id 4.4.4.4
log-adjacency-changes
redistribute static metric 50 metric-type 1
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0****************************************
network 192.168.5.0 0.0.0.255 area 0
network 192.168.6.0 0.0.0.255 area 0
neighbor 192.168.2.2********************************************************************
neighbor 192.168.1.2
default-information originate
Router 2
router ospf 1
area 4 stub
network 192.168.2.0 0.0.0.255 area 0   ********************************
network 192.168.8.0 0.0.0.255 area 4
650Router#sh frame-relay map
Serial0/0 (up): ip 192.168.1.1 dlci 102(0x66,0x1860), static,
              broadcast,
              CISCO
Serial0/1 (up): ip 192.168.2.1 dlci 103(0x67,0x1870), dynamic,
Serial0/1 (up): ip 192.168.2.2 dlci 103(0x67,0x1870), static,
              CISCO, status defined, active
2650Router#sh frame pvc 103
PVC Statistics for interface Serial0/1 (Frame Relay DTE)
DLCI = 103, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/1
  input pkts 5060          output pkts 6142         in bytes 437927
  out bytes 529083         dropped pkts 0           in pkts dropped 0
  out bcast pkts 89        out bcast bytes 3026
  pvc create time 1d21h, last time pvc status changed 06:48:42
MAhesh
Hi Andrew and darren
I am unable to set the clock rate on DCE  router it gives error
2691Router(config-if)#clock ?
  rate  Configure serial interface clock speed
2691Router(config-if)#clock rate 64000
This command applies only to DCE interfaces
mahesh
First thing remove "frame-relay intf-type dce" from routerA - then set the clock rate.
Then add static frame-relay maps to both routers defining the DLCI and IP address
i.e
Router1
int sx/x
frame-relay map ip 192.168.1.2 102 broadcast
Router2
int sx/x
frame-relay map ip 192.168.1.1 102 broadcast
Confirm ICMP pings from both sides - then change the OSPF interface type on both routers
int sx/x
ip ospf network point-to-point
Also remove keepalives from the frame serial interfaces "no keepalive"
Hi Andrew,
Thanks for the reply.
I did exactly as you said on R1 router
2691Router(config-if)#ip ospf network point-to-point
2691Router(config-if)#end
2691Router#sh run int se1/0
Current configuration : 226 bytes
interface Serial1/0
frame-relay map ip 192.168.2.2 103 broadcast
end
2691Router# config t
Enter configuration commands, one per line.  End with CNTL/Z.
2691Router(config)#int se1/0
This command applies only to DCE interfaces*****************************************
Still unable to add clock rate?
MAhesh
I am afriad you did not - paste the below into 2691Router
interface s1/0
no frame-relay intf-type dce
clock rate 64000
no keepalive
no frame-relay interfface-dlci 103
and on the other router paste
interface s1/0
no keepalive
frame-relay map ip 192.168.2.1 103 broadcast
Hi Andrew,
Thanks for reply
Still unable to add clock rate to R1
R1
Current configuration : 208 bytes
interface Serial1/0
no keepalive
end
R2
2650Router#sh run int se0/1
Current configuration : 244 bytes
interface Serial0/1
no keepalive
But now both interfaces are up up and ospf nei is full .
Only thing changed is Network type from Non Broadcast to Point to point.
2691Router#sh ip ospf int se1/0
  Internet Address 192.168.2.1/24, Area 0
  Process ID 1, Router ID 4.4.4.4, Network Type POINT_TO_POINT, Cost: 65*****************
  Transmit Delay is 1 sec, State POINT_TO_POINT
  Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
    oob-resync timeout 40
    Hello due in 00:00:07
  Supports Link-local Signaling (LLS)
  Index 4/4, flood queue length 0
  Next 0x0(0)/0x0(0)
  Last flood scan length is 6, maximum is 7
  Last flood scan time is 0 msec, maximum is 4 msec
  Neighbor Count is 1, Adjacent neighbor count is 1
    Adjacent with neighbor 192.168.8.3
  Suppress hello for 0 neighbor(s)
So Andrew in this case now it is point to point and there is no DR and BDR .
So we can consider this as Hub or spoke connection or just point to point?
So far no errors.
mahesh
That is correct there are no elections on a pt-pt link.  It is just a pt-pt connection.
Hi Andrew,
CRC errors occur again
R1
2691Router#sh int se1/0
  Keepalive not set
  Broadcast queue 0/64, broadcasts sent/dropped 60/0, interface broadcasts 60
  Last input 00:00:02, output 00:00:06, output hang never
  Last clearing of "show interface" counters 00:10:06
     55 packets input, 4620 bytes, 0 no buffer
     6 input errors, 6 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     60 packets output, 5040 bytes, 0 underruns
R2 is clean so far
2650Router#sh int se0/1
  Keepalive not set
  Broadcast queue 0/64, broadcasts sent/dropped 70/0, interface broadcasts 70
  Last input 00:00:04, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:11:32
     69 packets input, 5796 bytes, 0 no buffer
     155 packets output, 11555 bytes, 0 underruns
darren.g
Level 5
Level 5
mahesh18 wrote:
Hi all,
Router A config
Mahesh.
You need to set a clock rate on the interface on router A (the DCE) and also check your cabling - you're getting CRC and frame errors which could indicate some dodgy cables somewhere. I suspect the OSPF is changing state so constantly because your link is flapping, caused by either the lack of clocking or the framing errors.
Cheers.
Hi Andrew,
Many thanks for your time to point me in right direction.
Now there are no CRC errors.
Mahesh
No problem, glad to help.
