Frame relay point to point config-help needed
asimkamran
Hello all,
I need pointer to a link (I have already check cisco frame relay config documents on CCO) or document which will be able to provide info on how to configure frame relay point to point subinterfaces on R1, R2 and R3 where all three routers are connected to FR switch. Except for R1 which has two WAN links connected with FR switch, rest of the routers have only 1 WAN link.
I will be using OSPF for routing.
Thanks in advance
williamsdo
Level 3
Level 3
Hi , I read your posting and yu can configure FR point to point sub-interfaces off of your serial interface. Yu can then assigned the DLCI and other information on the link, the document link below should have all the information you need to complete the task.HTH
http://www.cisco.com/en/US/docs/ios/wan/configuration/guide/wan_cfg_frm_rly_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1003569
ohassairi
Level 5
Level 5
