Frame Relay + PPP and Virtual Templates
martynch1
I having a few issues with Frame Relay, PPP and Virtual Templates
I'm getting Vi1 PPP: Authorization required on two out of the three Routers and not sure where I have gone wrong, one of the 4 configs is below and the other 4 configs are atached: -
R1#show ip int brief
Interface IP-Address OK? Method Status Prot
ocol
FastEthernet0/0 10.80.80.1 YES NVRAM up up
Serial0/0 10.90.90.2 YES NVRAM up up
Serial0/1 unassigned YES NVRAM up up
Serial0/1.111 unassigned YES unset up up
Virtual-Access1 10.100.100.1 YES TFTP up down
Virtual-Template1 10.100.100.1 YES NVRAM down down
Virtual-Access2 unassigned YES unset down down
Loopback0 10.1.1.1 YES NVRAM up up
R1#show run
Building configuration...
Current configuration : 1053 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
enable password cisco
username R4 password 0 cisco
username R6 password 0 cisco
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
interface Loopback0
ip address 10.1.1.1 255.255.255.240
interface FastEthernet0/0
ip address 10.80.80.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 10.90.90.2 255.255.255.240
clockrate 2000000
interface Serial0/1
no ip address
encapsulation frame-relay
interface Serial0/1.111 point-to-point
frame-relay interface-dlci 101 ppp Virtual-Template1
interface Virtual-Template1
bandwidth 256
ip address 10.100.100.1 255.255.255.240
ppp authentication chap
ip classless
no ip http server
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
Debug PPP auth shows
10 Replies 10
wochanda
Level 4
Level 4
The problem you're running into here is a result of the 'ppp authentication chap' command. When you put this in, the router will attempt to authenticate all incoming connections. I see you've created a username/password pair for your other routers, which is a good first step. But, what you haven't done is configure the other routers to use the username/password pair. By default, a router will send its hostname and a null password during authenticaion. This isn't matching the 'cisco' password you put in.
Fix:
Place "ppp chap password cisco" under all Virtual-template interfaces on all 3 routers. This tells the router which password to use when requested to authenticate. If you also wanted to change the username, you can do "ppp chap hostname ".
Thanks for the swift reply wochanda, I put your fix in place "ppp chap password cisco" on all the Virtual interfaces but I still get the same error "Vi1 PPP: Authorization required"
This is the virtual interface after the changes: -
bandwidth 512
ip address 10.100.101.2 255.255.255.240
ppp chap password 0 cisco
Hope you can be of further help
Martyn
bandwidth 512
Martyn
Martyn
My first thought was similar to William and I almost replied with a suggestion that was quite similar to his. But then I noticed that your description of the error said that authorization was required (not authentication). I associate authorization requirements with configuration of AAA. But the config that you posted does not have any AAA configured. I wonder if other of the routers do have AAA configured and if this could be part of the problem.
Also I attempted to look at the file that was part of your original post. But I am not sure what file type "rar" is and the several attempts that I made to open it were not successful. I do not know if there is information in that file that would help us understand what is the problem. Could you clarify the file type (and what application reads that file type) or repost the file as a more common file type (txt, rtf, etc)
Rick
Rick
Thank you for the reply, the .rar are compressed files whiched can be opened with Winrar from http://www.rarlab.com/download.htm
Martyn
I don't see any AAA configured in the configs. Could you post a full 'debug ppp negotiation', not just the 'authorization required' on all routers? This way we can see if maybe a single router is ruining the party for the other 2.
I was just going through the config , In R5 and in interface s1/0 -- clock rate is missing and only R4 is having both the networks present in R1 and R6 and connected at S1/0 in R5 . Just thinking on logical part of establishing ppp , it might create a problem , but not very sure on ur authorization as said by others.
regards
vanesh k
R5 is a 3620 with a Cisco Serial Module
Serial1/0 is connected to a Cisco 1720 via couple of media converters, as you can see I have set the interface type but I still cannot set the clock rate, it complains about setting a clock rate on a DTE
frame-relay intf-type dce
interface Serial1/1 is connected via a Cisco back-to-back so I can put the DCE cable at either end of the kit
interface Serial1/2 is connected via a Cisco back-to-back so I can put the DCE cable at either end of the kit
Here is the aaa from the Routers
R1
aaa new-model
aaa authentication ppp default local
aaa authorization network default local
R4
aaa new-model
R6
aaa new-model
Debug information
R1
debug ppp authentication: -
Vi1 LCP: O CONFREQ [ACKsent] id 84 len 15
Vi1 LCP: AuthProto CHAP (0x0305C22305)
Vi1 LCP: MagicNumber 0x11E82BC9 (0x050611E82BC9)
Vi1 LCP: I CONFREQ [ACKsent] id 169 len 15
Vi1 LCP: MagicNumber 0x02A1910F (0x050602A1910F)
Vi1 LCP: O CONFACK [ACKsent] id 169 len 15
*Vi1 LCP: MagicNumber 0x02A1910F (0x050602A1910F)
Vi1 LCP: TIMEout: State ACKsent
Vi1 LCP: State is Listen
R4
Nothing
debug ppp negotiation: -
Vi1 LCP: TIMEout: State REQsent
Vi1 LCP: O CONFREQ [REQsent] id 222 len 15
Vi1 LCP: MagicNumber 0x02A588B9 (0x050602A588B9)
Vi1 LCP: O CONFREQ [REQsent] id 223 len 15
Vi1 LCP: O CONFREQ [REQsent] id 224 len 15
R6
Vi1 LCP: O CONFREQ [ACKsent] id 130 len 15
Vi1 LCP: MagicNumber 0x1205DAF3 (0x05061205DAF3)
Vi1 LCP: I CONFREQ [ACKsent] id 212 len 15
Vi1 LCP: MagicNumber 0x02A942A2 (0x050602A942A2)
Vi1 LCP: O CONFACK [ACKsent] id 212 len 15
Many thanks
Martyn
To try and make things easier to fault find I have narrowed down the Routers used so I'm only trying to connect from R4 to R6
Attached is the running config and interface status of R4, attached is the network diagram and they other configs
R4#
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname R4
aaa new-model
enable password 7 14141B180F0B
username R6 password 7 01100F175804 (which is cisco)
memory-size iomem 25
ip subnet-zero
interface Loopback0
ip address 10.4.4.4 255.255.255.248
interface Virtual-Template2
bandwidth 512
ip address 10.100.101.1 255.255.255.240
ppp chap password 7 030752180500
interface Serial0
no ip address
interface Serial0.112 point-to-point
frame-relay interface-dlci 102 ppp Virtual-Template2
ip address 10.40.40.1 255.255.255.240
speed auto
ip classless
no ip http server
Interface status
Serial0.112 unassigned YES unset up up
Virtual-Access1 10.100.101.1 YES TFTP up down
Virtual-Template2 10.100.101.1 YES NVRAM
