Router IOS
johnnymac
Level 4
Level 4
I accidentially removed deleted the IOS from a 1700 router, I havent reloaded yet so it's still up and working. Is there anyway I can restore whats been deleted? or do i need to download a replacement IOS and install a replacement IOS.
J Mac
8 Replies 8
ankbhasi
Hi Mac,
Once deleted its gone. You can check if your flash space is freed with that much space.
Good you have not reloaded the router yet.
So tftp the new IOS and make sure of your boot path and config reg value.
Ankur
Thanks for the advice,
It's a 1700 and this is the output from the show flash.
System flash directory:
File Length Name/status
1 1188 tart
[1252 bytes used, 8387356 available, 8388608 total]
8192K bytes of processor board System flash (Read/Write)
So i guess thats 8Mb right, obviously I try and get the most recent config i can is there anything else i should consider?
m.sir
Level 11
Level 11
You can try udelete command... If you didnt use squeeze command it could be working
check following link:
http://cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800b0ebd.html#31268
M.
smothuku
Level 11
Level 11
Hi Mac,
Check whether any IOS is present in flash using sh flash command.If there is no file then it would be better download the IOS and load it using tftp procedure.
Before reloading the router make sure that the config register value should be 0x2102.
satish
Thanks for all your help on this, i don't seem to have the undelete command available but it was worth a try. thanks again.
I have got this IOS from Cisco
File name - c1700-y-mz.122-17f.bin
Min. Memory - 8
(MB)
Min. Memory - 24
(MB)
This is the output from a show version on the router -
IOS (tm) C1700 Software (C1700-Y-M), Version 12.1(5), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 24-Oct-00 23:58 by cmong
Image text-base: 0x80008088, data-base: 0x805E2234
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
xxxxxx uptime is 25 weeks, 1 hour, 43 minutes
System image file is "flash:c1700-y-mz_121-5.bin"
cisco 1720 (MPC860) processor (revision 0x601) with 24576K/8192K bytes of memory
Processor board ID JAD0606009D (1781301420), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
Will this config be ok to TFTP?
Yes, You will be good to go with this. Just tftp it to the router and set the boot path to boot form the file, wr mem and you are good to go.
TFTP server to download
http://tftpd32.jounin.net/
HTH,
-amit singh
Thanks alot.
