Frame Relay Problem - Unable to Ping
ivebeenciscoed
Hi There
I am banging my head against a wall here with this problem....
I have a back to back frame relay set-up and the PVC status is Active and LMI is passing messages, however I am unable to ping the peer router.
I don't have a frame relay switch, so I am using one of the routers as a frame-relay switch which can provide LMI stats.
Here is the config:-
global config)# frame-relay switching
Router1 "DCE connection"
serial 0/0
Ip address 172.16.40.100 255.255.0.0
encapsulation frame-relay
no frame-relay inverse-arp
frame-relay intf-type dce
clock rate 64000
Frame map ip 172.16.20.100 104 broadcast
no shut
{BACK TO BACK SERIAL CONNECTION}
Router2 "DTE connection"
serial 0/0
ip address 172.16.20.100 255.255.0.0
frame map ip 172.16.40.100 104 broadcast
no shut
show frame pvc
PVC Statistics for interface Serial0/0 (Frame Relay DCE)
              Active     Inactive      Deleted       Static
  Local          1            0            0            0
  Switched       0            0            0            0
  Unused         0            0            0            0
DLCI = 104, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial0/0
  input pkts 96            output pkts 20           in bytes 6774
  out bytes 2080           dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
  in FECN pkts 0           in BECN pkts 0           out FECN pkts 0
  out BECN pkts 0          in DE pkts 0             out DE pkts 0
  out bcast pkts 0         out bcast bytes 0
  pvc create time 03:35:57, last time pvc status changed 01:55:54
show frame map
Serial0/0 (up): ip 172.16.40.100 dlci 104(0x68,0x1880), static,
              broadcast,
              CISCO, status defined, active
I don't know why I am unable to ping across to the other router... can someone please help me?
Have I missed something in my haste?
Thank you in advance :-)
Stephen
johnlloyd_13
Level 9
Level 9
your routers are on different subnets. try to amend your ip address settings and try again.
johnlloyd_13
Level 9
Level 9
How could I have missed that......... I need to wake up, slap myself around a bit !!!
Thank you very much johnlloyd_13, for pointing that out...
Such a basic mistake.
Merry X Mass
