frame-relay split-horizon
teru-lei
Hi All,
I just need to clarify split-horizon for frame-relay. I remember that for frame-relay point-to-multipoint interface, split-horizon will be disabled in physical interface by default, all subinterfaces and point-to-point interface will not be disabled. But I am not sure and I can not find the documents. Can anybody help me?
Thank You!
Best Regards
Teru Lei
ankurbhasin
Level 9
Level 9
Hi teru,
In frame replay point to multipoint enviroment which is also known as hub to spoke split horizon is enabled and that is the reason subinterface is recommended to avoid the problem for split horizon.
Check this out
http://www.alliancedatacom.com/manufacturers/cisco-systems/framerelay_design/subinterfaces.asp
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1918.htm
http://www.ciscopress.com/articles/article.asp?p=170741&seqNum=5&rl=1
Ankur
Thanks for your reply. I mean that I remember in certain condition by default cisco will disable split-horizon in frame-relay environment. I remember it's frame-relay multipoint physical interface. But not sure.
mounirmohamed
Dear Teru Lei,
Whene single physical interface si used routing problem arise, because due to Split-Horizon rule the update received on the interface cannot send back through the same interface
Best Regards,
Mounir Mohamed
