Frame Relay Switch help
neillix702
Hi folks, i have a Cisco 3725 router with 8 port (nm-8a/s 8-port async/sync serial) serial interface configured for Frame relay switch.  when i attached a cab le DCE/DTE cable on port se 1 or any other port it worked fine but when i attach a more than one cable it doesnt work at all except for one port.  if i unplugged the active connection, the one other port works.  please help
Giuseppe Larosa
use 64 kbps bit rate as clock rate or the module will not support additional ports
Hope to help
Giuseppe
i will try it and will let you know.  thanks Giuslar
i went ahead and applied 64000 and still dont work.  below is my config.
hostname FRAME_SWITCH
boot-start-marker
boot system flash c3725-advipservicesk9-mz.124-15.T12.bin
boot-end-marker
enable password cisco
no aaa new-model
memory-size iomem 15
ip cef
frame-relay switching
voice call carrier capacity active
archive
log config
  hidekeys
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial1/0
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
shutdown
no frame-relay inverse-arp
frame-relay intf-type dce
interface Serial1/1
no ip address
clock rate 64000
frame-relay route 102 interface Serial1/2 201
frame-relay route 103 interface Serial1/3 301
interface Serial1/2
no ip address
clock rate 64000
frame-relay route 201 interface Serial1/1 102
interface Serial1/3
no ip address
clock rate 64000
frame-relay route 301 interface Serial1/1 103
Hello Neillix702,
please post
show controller serial 1/0
show controller serial 1/1
show controller serial 1/2
show controller serial 1/3
Hope to help
Giuseppe
