Frame relay tc question
bellocarico
Reading on frame relay I can see that the time interval is for most of the providers 1/8 sec, which is 125 ms.
I'm trying a couple of configs on my lab I'm running into the following dilemma.
Please seethe config below:
interface Serial0
bandwidth 1544
no ip address
encapsulation frame-relay
no fair-queue
no arp frame-relay
frame-relay traffic-shaping
no frame-relay inverse-arp
interface Serial0.1 multipoint
ip address 192.168.0.1 255.255.255.252
frame-relay class SLOW
frame-relay map ip 192.168.0.2 501
interface Serial0.2 point-to-point
ip address 192.168.0.5 255.255.255.252
frame-relay class FAST
frame-relay interface-dlci 502
map-class frame-relay SLOW
frame-relay adaptive-shaping becn
frame-relay cir 28800
frame-relay bc 3600
frame-relay be 200
frame-relay mincir 24400
map-class frame-relay FAST
frame-relay cir 2048000
frame-relay bc 256000
frame-relay be 44000
frame-relay mincir 1544000
now... when I verify doing a show traffic-shape I get this:
Interface Se0.1
Access Target Byte Sustain Excess Interval Increment Adapt
VC List Rate Limit bits/int bits/int (ms) (bytes) Active
501 28800 475 3600 200 125 450 BECN
Interface Se0.2
502 2048000 13500 256000 44000 32 8192 -
Why has the time interval changed to 32ms in serial 0.2?
Should't have staid set to 125ms (1/8 second)?
Also, what does the Increment (bytes) rapresent exacplty?
Thanks to read!
pkhatri
Level 11
Level 11
Q: Why has the time interval changed to 32ms in serial 0.2?
IOS will allow the following maximum values of Tc depending on the configured CIR:
o For CIR <= 640007 bps, Tc = 125ms
o For 640000 < CIR <= 1280007 bps, Tc = 63ms
o For CIR > 1280007 bps, Tc = 32ms
If you happen to configure a CIR and Bc that results in a Tc that is less than the maximum allowed for that CIR, IOS will accept it as long as it is greater than the minimum allowed Tc of 10ms. If the calculated Tc happens to be greater than the maximum from above, IOS will force it to be that maximum value. In your case, since CIR=2048000, the max Tc you can use is 32ms. And that is why you see that.
Q: Also, what does the Increment (bytes) rapresent exacplty?
The Increment(bytes) is the number of bytes that will be sent in each Tc interval. In your first example, the increment is 450 bytes, which is 3600 bits, which matches your Bc.
For the second case, it is 8192 bytes = 65536 bytes, which is worked out as 2048000 * 0.032 = 65536.
Pls do remember to rate posts...
Paresh
pkhatri
Level 11
Level 11
Paresh
Thanks for that! It really helps.
I just miss one thing...
When you say:
I've tried (inside the map-class)
frame-relay tc 15 (ms)
which is less than 32 and more than 10, but the output of the sh traffic-shape it's still the same:
Interface Se0.2
502 2048000 8750 65536 4464 32 8192 -
You see? Interval (ms) = 32
Everything else it's clear, I just miss this point.
Hi again,
The 'frame-relay tc' command is useful only when using frame-relay policing and not shaping.
To test what I indicated in my post, use the following config:
map-class frame-relay class1
frame-relay cir 128000
frame-relay bc 1000
According to the calculation for Tc, the above parameters should result in a Tc of 1000/128000 = 7.8 ms. However, when you do a 'show frame-relay pvc' command, you will see that the interval will be set to 10ms. That is what I meant.
Pls do remember to rate the post if it helps.
Paresh
