Frame-Relay Traffic Shaping --- Help
rafaelgarcia
I have a 1760 router dropping packets on its serial interface. By TAC I need to configure QoS on the frame-relay circuit even though my CIR and access rate is 1.5M. They stated that I need to do so since I have voice running on my T1. I have never reached 1.5M on my T1.
I would like to here your feedback about this.
Also I would like to know how to configure the access list related to the class-map. Can somebody provide me with some sample configurations?
I appreciate your help.
globalnettech
Level 5
Level 5
Hello Rafael,
you might want to try Frame Relay Traffic Shaping first. Your configuration for this would look as following:
interface Serial0
encapsulation frame-relay
frame-relay traffic-shaping
frame-relay class SHAPE
map-class frame-relay SHAPE
frame-relay cir 1536000
frame-relay bc 153600
If this does not render the desired result, try the following QoS policy for voice traffic:
interface Serial0
service-policy output VOIP
class-map voice
match access-group 101
policy-map VOIP
class voice
priority percent 50
access-list 101 permit tcp any any eq 1720
access-list 101 permit udp any range 16384 32767
Can you try this and see if it makes a difference for you ?
GNT
