frame-relay traffic shaping question
bellocarico
when in map-class mode, what is the difference between:
Router(config-map-class)#frame-relay traffic-rate 15440000
and
Router(config-map-class)#frame-relay CIR 1544000
mheusinger
Level 10
Level 10
well ... a factor of ten!? ;-)
Now seriously both will basically give the same CIR, the difference will be in Bc, Be. Have a look at:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_command_reference_chapter09186a00801a7f4c.html#wp1075283
Hope this helps
Martin
