Frame Relay vs. PPP Tail
mlitka
Level 2
Level 2
We have a provider-based MPLS network and the majority of our access tails are provisioned using Frame-Relay. I believe this is just a means to provide access as we aren't getting any FECNs,BECNs, etc.
I believe we may have the option to request an access tail using ppp encapsulation instead of frame relay.
Can anyone tell me the advantages/disadvantages of ppp vs. frame relay when used strictly as an access medium?
5 Replies 5
Edison Ortiz
In a hub-spoke design, I prefer going with frame-relay. With frame-relay, you are able to create subinterfaces thus providing a more hierarchal design.
If you are going with a point-to-point design, then you can use either access medium but go with the easiest with is ppp :)
Why do the providers seem to always default to Frame-relay? I don't ever get asked which one I want to use. Strange.
MPLS is often a many-to-many topology and frame-relay fits the bill based on the feature I explained before.
To be clear, I am talking about a Service Provider MPLS network here. When would you need more than 1 DLCI or subinterface on the CE in this situation?
With MPLS, you can configure a location to talk directly to many locations, not directly to the hub. On this case, you need more than 1 DLCI.
