FRAME RELAY
ahmed.abdraboh
i have one router cisco 3925 with two serials Hwic 2T..these two interface are configured for load sharing
i have now one interface is up up on the physical and also the sub interface is also up up and working properly
but the other interface is up down for the physical and down down for the subinterface. and it is not working.
please check these shows outputs.
Serial0/1/0                unassigned      YES NVRAM  up                    up
Serial0/1/0.16             172.16.16.2     YES NVRAM  up                    up
Serial0/1/1                unassigned      YES NVRAM  up                    down
Serial0/1/1.16             172.16.16.6     YES NVRAM  down                  down
PVC Statistics for interface Serial0/1/1 (Frame Relay DTE)
              Active     Inactive      Deleted       Static
  Local          0            0            1            0
  Switched       0            0            0            0
  Unused         0            0            0            0
DLCI = 16, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0/1/1.16
  input pkts 0             output pkts 8            in bytes 0
  out bytes 1690           dropped pkts 0           in pkts dropped 0
  out pkts dropped 0                out bytes dropped 0
5 Replies 5
Peter Paluch
Hi Ahmed,
Please post the outputs of the following commands:
  • show running-config
  • show interfaces serial0/1/0
  • show interfaces serial0/1/1
  • show controllers serial0/1/0
  • show controllers serial0/1/1
Please try to attach them as complete as possible, remove only the sensitive information. These are necessary for us to help you further.
Best regards,
Peter
that is show run
Current configuration : 7418 bytes
! Last configuration change at 12:21:41 Cairo Wed Nov 10 2010
version 15.1
hostname Cairo-GW-1
boot-start-marker
boot-end-marker
card type e1 0 0
no aaa new-model
clock summer-time Egypt recurring last Fri Apr 0:01 last Fri Sep 0:01
network-clock-participate wic 0
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-4ess
voice-card 0
dspfarm
dsp services dspfarm
license udi pid C3900-SPE100/K9 sn FOC14300RV8
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
clock source internal
pri-group timeslots 1-31 service mgcp
class-map match-all Voice-Signaling
match access-group 160
class-map match-all Voice-Traffic
match access-group 161
class-map match-all Video-Conference
match access-group 180
policy-map Policy1
class Voice-Signaling
    bandwidth percent 7
  set ip dscp af31
class Voice-Traffic
    priority percent 25
  set ip dscp ef
class Video-Conference
    bandwidth percent 25
  set ip dscp af13
class class-default
    fair-queue
interface GigabitEthernet0/0
ip address 10.10.80.11 255.255.255.0
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.20.11 255.255.255.0
ip nbar protocol-discovery
ip flow ingress
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn bchan-number-order ascending
no cdp enable
interface Serial0/1/0
bandwidth 2000
no ip address
ip flow ingress
encapsulation frame-relay IETF
no shutdown
no fair-queue
clock rate 2000000
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/1/0.16 point-to-point
bandwidth 2000
ip address 172.16.16.2 255.255.255.252
ip accounting output-packets
ip load-sharing per-packet
ip flow ingress
frame-relay interface-dlci 16
  class Class1
bandwidth 2000
no ip address
ip flow ingress
no shutdown
no fair-queue
clock rate 2000000
interface Serial0/1/1.16 point-to-point
bandwidth 2000
ip address 172.16.16.6 255.255.255.252
ip flow ingress
  class Class1
router rip
version 2
network 10.0.0.0
network 172.16.0.0
network 172.20.0.0
distribute-list LOOP in Serial0/1/0.16
distribute-list CAIRO_UPDATE out Serial0/1/0.16
distribute-list LOOP in Serial0/1/1.16
distribute-list CAIRO_UPDATE out Serial0/1/1.16
no auto-summary
ip forward-protocol nd
ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/1
ip flow-export version 5
ip flow-export destination 10.10.80.103 9996
ip flow-export destination 10.10.80.110 2055
ip access-list standard BACK_OFF
permit any
ip access-list standard CAIRO_UPDATE
permit 0.0.0.0
permit 10.10.0.0 0.0.255.255
ip access-list standard LOOP
deny   10.10.0.0 0.0.255.255
permit any
map-class frame-relay Class1
frame-relay cir 4096000
service-policy output Policy1
logging 10.10.80.110
access-list 160 permit tcp any eq 1720 any
access-list 160 permit tcp any any eq 1720
access-list 160 permit tcp any eq 2000 any
access-list 160 permit tcp any any eq 2000
access-list 161 permit udp any any range 16384 32767
access-list 180 permit ip any host 10.10.80.240
access-list 180 permit ip any host 10.10.80.241
access-list 180 permit ip host 10.10.80.240 any
access-list 180 permit ip host 10.10.80.241 any
nls resp-timeout 1
cpd cr-id 1
snmp-server community public RO
snmp-server community private RW
snmp-server community ugdc RW
snmp-server ifindex persist
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps xgcp
snmp-server enable traps envmon
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps atm subif
snmp-server enable traps cnpd
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps frame-relay multilink bundle-mismatch
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmulticast
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps ipsla
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps voice poor-qov
snmp-server enable traps dnis
snmp-server host 10.10.80.42 ugdc
control-plane
voice-port 0/0/0:15
echo-cancel coverage 64
voice-port 0/2/0
signal groundStart
timing hookflash-out 50
voice-port 0/2/1
signal groundStart
voice-port 0/2/2
signal groundStart
voice-port 0/2/3
signal groundStart
ccm-manager redundant-host 10.10.20.6
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.10.20.5
ccm-manager config
mgcp
mgcp call-agent 10.10.20.5 2427 service-type mgcp version 0.1
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.10.20.6 identifier 2 priority 2 version 7.0
sccp ccm 10.10.20.5 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register CONf866f2421181
associate profile 2 register MTPf866f2421181
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 22
associate application SCCP
shutdown
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 7
shutdown
dial-peer voice 999020 pots
service mgcpapp
port 0/2/0
dial-peer voice 999021 pots
service mgcpapp
port 0/2/1
dial-peer voice 999022 pots
service mgcpapp
port 0/2/2
dial-peer voice 999023 pots
service mgcpapp
port 0/2/3
gatekeeper
shutdown
scheduler allocate 20000 1000
ntp server 10.10.80.10
end
sh controller s 0/1/1
Hardware is SCC
DTE V.35
Clock Freq detected Rx clk/Tx clk 1963418/1963420 (+-10%)
idb at 0x127EA17C, driver data structure at 0x15BDE24
wic_info 0x127F11E8
WIC Serial Global Registers: (0xEC890000)
sti_errintr_en      (0004): 0x00000000  scc_ctrl_regs       (1004): 0x0020
mgmt_intr_status    (1010): 0x0010      netio_intr_status   (1012): 0x0000
mgmt_intr_enable    (1020): 0x00CA      netio_intr_enable   (1022): 0x000C
timer_0_7_enable    (1024): 0x0000      timer_16_19_enable  (1026): 0x0000
timer_0_1_program   (1030): 0x0000      timer_2_3_program   (1032): 0x0000
timer_4_5_program   (1034): 0x0000      timer_6_7_program   (1036): 0x0000
timer_16_program    (1040): 0x0000      timer_17_program    (1042): 0x0000
timer_18_program    (1044): 0x0000      timer_19_program    (1046): 0x0000
WIC Serial SCC Registers: (2)
ch_mode_cfg         (1120): 0x08019031  ch_flag_cfg         (1124): 0x007E
ch_flwctrl_cfg      (1128): 0x0000      ch_intr_enable      (112C): 0x09FF
ch_cmd_stat         (112E): 0x0050
WIC Serial DMA Registers:
Rx ring_start_ptr   (2040): 0x3DB92680  Rx ring_mask_index  (2044): 0x00F80068
internal_desc_stat  (2048): 0x0400060C  internal_buff_addr  (204C): 0x3DB98760
internal_context    (2050): 0x00000013  internal_fifo_data  (2054): 0x3DB98E1B
Tx ring_start_ptr   (2240): 0x3DB927C0  Tx ring_mask_index  (2244): 0x03F80170
internal_desc_stat  (2248): 0x01C00000  internal_buff_addr  (224C): 0x3D901788
internal_context    (2250): 0x00000201  internal_fifo_data  (2254): 0x5ED4FFFF
WIC Serial Interface Registers:
intf_ctrl           (3020): 0x1000      modem_ctrl          (3022): 0x01D8
flow_ctrl           (3024): 0xB070      brg dvdr            (3026): 0x0000
WIC TDM/FREQ Counter Registers:
tdm_control         (3100): 0x0000      tdm_a_8k_divider    (3102): 0x0000
tdm_b_8k_divider    (3104): 0x0000
freq_count_port_sel (310A): 3           freq_count          (310C):  1374400
TDM Control Registers:
  tmdsw_ctl                              (addr 0xEC8B0040): 0x00000000
  vmcr[0]                                (addr 0xEC8B0060): 0x00000000
  vmcr[1]                                (addr 0xEC8B0064): 0x00000000
  vmcr[2]                                (addr 0xEC8B0068): 0x00000000
  vmcr[3]                                (addr 0xEC8B006C): 0x00000000
  ntr_cr0                                (addr 0xEC8B0078): 0x00000000
  ntr_cr1                                (addr 0xEC8B0080): 0x00000000
  tpllr_cr                               (addr 0xEC8B0088): 0x00000000
  sm_tdm_cr                              (addr 0xEC8B0070): 0x00000000
  pvdm_tdm_cr                            (addr 0xEC8B0074): 0x00000000
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
22 transmitter CTS losts
8436504 rxintr, 5119925 txintr, 0 rxerr, 0 txerr
1 tx_abort 1 tx_reset
tx_limited = 1(2) tx_count = 0
Receive Ring
rxr head (22)(0x3DB92730), rxr tail (0)(0x3DB92680)
  rmd(3DB92680): stats_len 8400060C buff_addr 3DB95360
  rmd(3DB92688): stats_len 8400060C buff_addr 3DBA1CE0
  rmd(3DB92690): stats_len 8400060C buff_addr 3DBA1CE0
  rmd(3DB92698): stats_len 8400060C buff_addr 3DB959E0
  rmd(3DB926A0): stats_len 8400060C buff_addr 3DB9A7E0
  rmd(3DB926A8): stats_len 8400060C buff_addr 3DBA0960
  rmd(3DB926B0): stats_len 8400060C buff_addr 3DB93FE0
  rmd(3DB926B8): stats_len 8400060C buff_addr 3DBA02E0
  rmd(3DB926C0): stats_len 8400060C buff_addr 3DB9D560
  rmd(3DB926C8): stats_len 8400060C buff_addr 3DB9C1E0
  rmd(3DB926D0): stats_len 8400060C buff_addr 3DBA0FE0
  rmd(3DB926D8): stats_len 8400060C buff_addr 3DB9CEE0
  rmd(3DB926E0): stats_len 8400060C buff_addr 3DB99AE0
  rmd(3DB926E8): stats_len 8400060C buff_addr 3DB98DE0
  rmd(3DB926F0): stats_len 8400060C buff_addr 3DB98760
  rmd(3DB926F8): stats_len 8400060C buff_addr 3DB9E260
  rmd(3DB92700): stats_len 8400060C buff_addr 3DB94CE0
  rmd(3DB92708): stats_len 8400060C buff_addr 3DB9A160
  rmd(3DB92710): stats_len 8400060C buff_addr 3DB980E0
  rmd(3DB92718): stats_len 8400060C buff_addr 3DB966E0
  rmd(3DB92720): stats_len 8400060C buff_addr 3DB9AE60
  rmd(3DB92728): stats_len 8400060C buff_addr 3DB92C60
  rmd(3DB92730): stats_len 8400060C buff_addr 3DB9BB60
  rmd(3DB92738): stats_len 8400060C buff_addr 3DB973E0
  rmd(3DB92740): stats_len 8400060C buff_addr 3DBA1660
  rmd(3DB92748): stats_len 8400060C buff_addr 3DB9DBE0
  rmd(3DB92750): stats_len 8400060C buff_addr 3DB99460
  rmd(3DB92758): stats_len 8400060C buff_addr 3DB97A60
  rmd(3DB92760): stats_len 8400060C buff_addr 3DBA29E0
  rmd(3DB92768): stats_len 8400060C buff_addr 3DB9E8E0
  rmd(3DB92770): stats_len 8400060C buff_addr 3DB9EF60
  rmd(3DB92778): stats_len 8400060C buff_addr 3DB9C860
Transmit Ring
txr head (81)(0x3DB92A48), txr tail (81)(0x3DB92A48)
  tmd(3DB927C0): sts_len 00C00000 buf_addr 3D8C6D4A
  tmd(3DB927C8): sts_len 01C00000 buf_addr 3D93A54A
  tmd(3DB927D0): sts_len 01C00000 buf_addr 3D8D074A
  tmd(3DB927D8): sts_len 01C00000 buf_addr 3D902C4A
  tmd(3DB927E0): sts_len 01C00000 buf_addr 3D95EA4A
  tmd(3DB927E8): sts_len 01C00000 buf_addr 3D901E4A
  tmd(3DB927F0): sts_len 01C00000 buf_addr 3D96AE4A
  tmd(3DB927F8): sts_len 01C00000 buf_addr 3D8F764A
  tmd(3DB92800): sts_len 01C00000 buf_addr 3D96534A
  tmd(3DB92808): sts_len 01C00000 buf_addr 3D96144A
  tmd(3DB92810): sts_len 01C00000 buf_addr 3D94774A
  tmd(3DB92818): sts_len 00C00000 buf_addr 3D96F44A
  tmd(3DB92820): sts_len 01C00000 buf_addr 3D8F224A
  tmd(3DB92828): sts_len 01C00000 buf_addr 3D91054A
  tmd(3DB92830): sts_len 01C00000 buf_addr 3D8DB64A
  tmd(3DB92838): sts_len 01C00000 buf_addr 3D91914A
  tmd(3DB92840): sts_len 01C00000 buf_addr 3D8C7B4A
  tmd(3DB92848): sts_len 01C00000 buf_addr 3D94004A
  tmd(3DB92850): sts_len 00C00000 buf_addr 3D920F4A
  tmd(3DB92858): sts_len 01C00000 buf_addr 3D8BFD4A
  tmd(3DB92860): sts_len 00C00000 buf_addr 3D8C274A
  tmd(3DB92868): sts_len 01C00000 buf_addr 3D8E344A
  tmd(3DB92870): sts_len 01C00000 buf_addr 3D93E44A
  tmd(3DB92878): sts_len 01C00000 buf_addr 3D92B04A
  tmd(3DB92880): sts_len 01C00000 buf_addr 3D8FED4A
  tmd(3DB92888): sts_len 01C00000 buf_addr 3D8C3C4A
  tmd(3DB92890): sts_len 01C00000 buf_addr 3D8FF44A
  tmd(3DB92898): sts_len 01C00000 buf_addr 3D8FDF4A
  tmd(3DB928A0): sts_len 00C00000 buf_addr 3D95114A
  tmd(3DB928A8): sts_len 01C00000 buf_addr 3D959D4A
  tmd(3DB928B0): sts_len 00C00000 buf_addr 3D95F14A
  tmd(3DB928B8): sts_len 01C00000 buf_addr 3D96844A
  tmd(3DB928C0): sts_len 01C00000 buf_addr 3D8DCB4A
  tmd(3DB928C8): sts_len 01C00000 buf_addr 3D97024A
  tmd(3DB928D0): sts_len 01C00000 buf_addr 3D94934A
  tmd(3DB928D8): sts_len 00C00000 buf_addr 3D94464A
  tmd(3DB928E0): sts_len 00C00000 buf_addr 3D8D2A4A
--More--
sh controller s 0/1/0
Interface Serial0/1/0
Hardware is SCC
DTE V.35
Clock Freq detected Rx clk/Tx clk 1963425/1963420 (+-10%)
wic_info 0x127F11E8
sh int s 0/1/0
Cairo-GW-1#sh int s 0/1/0
Serial0/1/0 is up, line protocol is up
  Hardware is WIC MBRD Serial
  MTU 1500 bytes, BW 2000 Kbit/sec, DLY 20000 usec,
     reliability 255/255, txload 54/255, rxload 11/255
  Encapsulation FRAME-RELAY IETF, loopback not set
  Keepalive set (10 sec)
  LMI enq sent  5584, LMI stat recvd 5552, LMI upd recvd 0, DTE LMI up
  LMI enq recvd 0, LMI stat sent  0, LMI upd sent  0
  LMI DLCI 0  LMI type is ANSI Annex D  frame relay DTE  segmentation inactive
  FR SVC disabled, LAPF state down
  Broadcast queue 0/64, broadcasts sent/dropped 2975/2, interface broadcasts 2040
  Last input 00:00:03, output 00:00:03, output hang never
  Last clearing of "show interface" counters 16:00:29
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 85952
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 92000 bits/sec, 39 packets/sec
  5 minute output rate 430000 bits/sec, 56 packets/sec
     8440026 packets input, 4113989915 bytes, 0 no buffer
     Received 0 broadcasts (2004 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     9028840 packets output, 7382004903 bytes, 0 underruns
     0 output errors, 0 collisions, 17 interface resets
     0 unknown protocol drops
     2 carrier transitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
sh int s 0/1/1
Serial0/1/1 is up, line protocol is up
     reliability 137/255, txload 5/255, rxload 2/255
  LMI enq sent  5466, LMI stat recvd 149, LMI upd recvd 0, DTE LMI up
  Broadcast queue 0/64, broadcasts sent/dropped 126/1, interface broadcasts 83
  Last input 00:00:20, output 00:00:00, output hang never
  Last clearing of "show interface" counters 16:01:22
  5 minute input rate 21000 bits/sec, 27 packets/sec
  5 minute output rate 46000 bits/sec, 31 packets/sec
     39694 packets input, 4389948 bytes, 0 no buffer
     Received 0 broadcasts (59 IP multicasts)
     3156869 runts, 0 giants, 0 throttles
     3162252 input errors, 5138 CRC, 0 frame, 0 overrun, 0 ignored, 245 abort
     44853 packets output, 14461186 bytes, 0 underruns
     0 output errors, 0 collisions, 1747 interface resets
     39 carrier transitions
that is all and thx alot for your fast response
Hello Ahmed,
A couple of suggestions.
First, remove the frame-relay lmi-type ansi command from your interfaces Serial0/1/0 and Serial0/1/1. Setting the LMI type statically is not necessary since the IOS 11.2, and may in fact cause trouble if the LMI type on the Frame Relay switch is different. It is best to leave the IOS to detect the LMI type automatically, therefore, I strongly recommend removing this command until you know precisely that the connection will not work without it. After removing this command, shutdown and reactivate the physical interface (take care - this will disrupt connectivity for a moment).
Second, the show interfaces s0/1/1 has revealed that this interface received an inordinate number of invalid frames:
This are several possible causes for this - wrong cabling, bad or improperly seated connectors, wrong encapsulation (are you really connected to a Frame Relay circuit via the S0/0/1 interface?), problems with the modem, noise at the leased line, etc. Can you check this?
As a small experiment, if you swap the cables between interface S0/1/0 and S0/1/1, do the interfaces come up? The addressing will be incorrect but right now I am more interested simply in the physical and data link layer functionality.
What is interesting is that in your current output, the S0/1/1 is up/up. Perhaps it is going up and down in cycles.
Best regards,
Peter
i changed the modem and interface  s 0/1/1 is up up as you see in the last post.
but i have a lot of packet loss on this interface about 30% packet loss on this interface.
i think the configuration is ok.
the lmi type and the frame relay type ...were provided to me by the ISP.
so what was the problem
Ahmed,
I do not have any direct answer about what is causing your problem. I have pointed out in my last reply that the error count on your S0/1/1 interface is very, very high, and in my opinion, this requires urgent attention. I have also pointed out possible causes of input errors - it is up to you to thoroughly verify each and every of them, and watch the interface continuously whether the input errors increase. In general, those input errors are caused by Layer1 or Layer2 issues and they may probably account for your current packet loss as well.
About the FR settings your ISP gave you - okay, he may have given you these values but I tend in this case to leave the automatic detection activated, just in case. But if both interfaces currently appear to be able to transport frames, you may leave the settings unchanged.
Please keep me informed.
Best regards,
Peter
