Frame relay
djalijay83
Hello am new here,can someone send me PT step by step on how to install frame relay.Thank you
it is pretty straightforward. Have a look at the video below:
https://www.youtube.com/watch?v=VYrTFfo-Y0A
Hello
Can you elaborate on your FR?
As it depends on what type of Frame relay you are wanting to test and the topolgy you would like to use. .
Hub-spoke FR ( broadcast, point-to-point, point-2-multipoint, mulitpoint ) <- require a frame relay switch)
Back-to back FR
Kind Regards
Paul
Martin L
The main issue is with making cloud FR provider cloud to meed your desired topology.  I have studied and passed CCNA when FR was on exam long time ago. Here are my several examples made for PT.  They are old but still should be ok for new PT version.  Make sure you unzip some of files.  Note: there are 2 examples made for GNS3 standalone older version, those are:  "FR with router EIGRP mulit-point.zip"  and FR with router EIGRP no subs.zip".  Link valid for 14 days,  see link https://dropmefiles.com/yYjBb
Regards, ML
**Please Rate All Helpful Responses **
