Frame-rely troubleshooting
chrisblaze
I have been trying to configure frame relay for the past two days, my protocol will not stay up. Below is my running config on both routers:
R1
sh run
Building configuration...
Current configuration : 1132 bytes
version 12.3
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$uHaf$uhnNzXlrRKb2jSD7F1IFt/
username R2 password 0 cisco
memory-size iomem 10
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address 10.0.0.1 255.255.255.128
duplex auto
speed auto
interface Serial0/0
ip address 172.16.0.1 255.255.255.252
encapsulation ppp
clockrate 64000
no fair-queue
ppp authentication chap
interface BRI0/0
no ip address
shutdown
interface Serial0/1
ip address 172.16.0.9 255.255.255.252
encapsulation frame-relay
frame-relay map ip 172.16.0.10 101 broadcast
frame-relay lmi-type ansi
router rip
version 2
network 10.0.0.0
network 172.16.0.0
ip http server
no ip http secure-server
ip classless
banner motd ^CHELP!!!^C
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
end
and here is R3:
sh run
Current configuration : 1156 bytes
version 12.3
hostname R3
boot-start-marker
boot-end-marker
enable secret 5 $1$Xi9C$K2BeD99qLoFVfZlMprcIk0
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
bandwidth 64
ip address 172.16.0.10 255.255.255.252
no fair-queue
frame-relay map ip 172.16.0.9 102 broadcast
interface BRI0/0
no ip address
shutdown
interface FastEthernet0/1
ip address 10.0.0.129 255.255.255.128
duplex auto
speed auto
interface Serial0/1
ip address 172.16.0.6 255.255.255.252
router rip
version 2
network 10.0.0.0
network 172.16.0.0
ip http server
ip classless
banner motd ^CLast Lab!!!^C
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
end
Can someone tell me what I did wrong?
16 Replies 16
Christopher
If the router are connected back to back then there are 2 things that you must change.
- configure both serial interfaces with "no keepalive". Since the keepalive in Frame Relay is provided by LMI and since there is no LMI without a device operating as a frame relay switch, then you need to configure the interfaces to not use keepalives.
- the DLCI on both interfaces must be the same. They can be DLCI 100 or they can be DLCI 101. But you can not have 100 on one end and 101 on the other end if they are connected back to back with no frame relay switch. Having different DLCIs on the interface works fine if there is a frame relay switch. But with no frame relay switch both interfaces must have the same DLCI.
I am not sure that the frame relay map is correct (the way you have configured it the map on one router is pointing to the DLCI of the other router, but the map should point to the DLCI of the local router). But that is less important than fixing the keepalive and DLCI values. And when both interfaces are using the same DLCI then it will be obvious that both maps should have the same DLCI.
Rick
Rick
Thanks for all the help, the problem was because I had to different DLCIs on the same serial connections, also Rick hit it on the head, when I added the "no keeplive" to both ends along with matching DLCIs, the protocol came up.
Thanks!!!!
