framerelay back-to-back
   I have R1-R2 connected by serial link. There are two sub interfaces on each side connecting these two. How do we configure frame relay on these two sub interfaces without disabling keepalive?
Balajee
cadet alain
just make one router a frame-relay switch:
R1
enable
config t
frame-relay switching
int s1/0
encapsulation frame-relay
frame-relay intf-type dce
no shut
int s1/0.12
ip address 10.0.0.1 255.0.0.0
frame-relay interface-dlci 201
R2
enable
config t
int s1/0
no shut
int s1/0.21
ip address 10.0.0.2 255.0.0.0
Alain
cadet alain
R1
enable
config t
int s1/0
no shut
int s1/0.12
R2
enable
config t
int s1/0
no shut
int s1/0.21
Alain
I just tried this...it didn't work. Can you please let me know if it works for you?
- Balajee
sorry I posted the config quickly and forgot something:
for each subinterface you must specify if it is multipoint or point-to-point before you can configure it
int s1/0.12 multipoint or  int s1/0.12 point-to-point for example
Alain
