FRTS on sub-interface
adirinaldi
I tried to configure FRTS on my spoke router (branch), but when i applied "frame-relay traffic-shaping" command, I could not reach (ping) my Hub routers (HQ), and as soon as i undo the "frame-relay traffic-shaping" its back to normal. I'm using CISCO2621XM with image c2600-adventerprisek9-mz.124-7.bin.
!Branch Routers A
interface Serial0/0
no ip address
encapsulation frame-relay
ip ospf priority 0
no dce-terminal-timing-enable
frame-relay lmi-type cisco
interface Serial0/0.246 multipoint
ip address 150.x.x.4 255.255.255.0
ip ospf authentication message-digest
ip ospf message-digest-key 1 md5 ciscomd51
ip ospf network non-broadcast
ip ospf 1 area 246
frame-relay map ip 150.50.246.2 401 broadcast
frame-relay map ip 150.50.246.4 401
frame-relay map ip 150.50.246.6 401
frame-relay interface-dlci 401
class CIR64
no frame-relay inverse-arp
dgahm
Level 8
Level 8
Does your map class look something like this?
map-class frame-relay CIR64
frame-relay adaptive-shaping becn
frame-relay cir 128000
frame-relay bc 16000
frame-relay mincir 64000
What output do you get from:
sh traffic-shape serial 0/0.246
You may not need traffic shaping if you only have a single PVC and the port (circuit) speed matches your burst rate. It is usually the hub site where FRTS becomes critical.
Please rate helpful posts.
dgahm
Level 8
Level 8
my map class look like this:
frame-relay cir 64
frame-relay bc 1000
frame-relay be 0
and you just reminded me that the unit for "cir" is bps (not kbps), thank you very much, really helpful. i was thinking that the problem is on the interface. stupid me ;)
