FTP Fails
vatsey.sharad
This is one of the interesting issue which i am facing. Whenever my client tries to send a file less than 1kb, the file is transmitted successfully over ftp, but for files greater than 1kb, the files are not being transferred, instead a 0 kb file is created on the destination server.
1. Link utilization is fine
2. No crc's etc on the link.
3. server settings are perfect.
4. MTU settings default to 1500 for the WAN link.
Kindly advise.
6 Replies 6
lgijssel
Level 9
Level 9
This can hardly be anything but MTU related.
Try what happens when you use the command " ip tcp adjust-mss 1300" on the LAN interface of your Internet router.
regards,
Leo
Well nothing seems to change, even after implementing "ip tcp adjust-mss 1300" ftp for large files is still failing.
Two other things to check:
-Any Policies or route maps there that might be messing with the df-bit?
-Any restrictions (for the user) about the file size on the server?
Are you able to upload files locally?
regards,
Leo
Are you certain that its not related to the hosts i.e. Server and Client.
Interesting issue, please keep us posted about the matter.
Wilson Samuel
stephen.stack
Level 4
Level 4
Just jumping in and taking a guess here. My previous experience of FTP not working are related to MTU and MSS settings on both internal and external Ports. Are you using DSL as you WAN connection. If so then please apply the following.
Interface fa0/0
description ***INTERNAL INTERFACE***
ip address 192.168.0.254 255.255.255.0
ip tcp adjust-mss 1452
no shut
interface fa0/1
description ***EXTERNAL INTERFACE***
ip address 5.5.5.5 255.255.255.192
ip mtu 1492
no shut
If this does not work, then let us know how your router is configured and what type of wan links are being used.
HTH, Please rate if it does.
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
Danilo Dy
Can you tell us more on the following?
- FTP Client apps and version
- FTP Server apps and version
- FTP Server OS and version
Also check the FTP server settings and the destination folder settings.
Dandy
