FTP Proxy - NAT v Public IP
pauldurnien
Trying to look at confiuring our 3845 so that I have a unique public IP on the interface of our FTP server.
Currently we are 'ip nat inside' on the inside interface so everything will be NATed to the WAN interface.  Clearly If I configure a public IP on our FTP proxy this won't work.  But it's not clear how I can - nat * but <this ip>.
Alternatively I will consider other options that maintain NATing.
However NATing seems to introduce several problems, particualry because we ned to do both active and passive FTP.
a little cryptic but ...
Internet <> Router/NAT <> ASA <> External NIC <server> Internal NIC <> Internal Network.
Any advice would be helpful.
skothiya
What is the access-list that you are using to define NAT ?
Here is the relevent entries in the config.  You can see that NAT is on for both inside and outside interfaces.
interface GigabitEthernet0/0
description Inside interface
ip address 172.18.0.3 255.255.255.0
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip policy route-map SECONDARY
duplex full
speed auto
interface GigabitEthernet0/1
ip address 12.x.x.130 255.255.255.240
ip access-group 101 in
ip nat outside
ip route-cache flow
duplex auto
speed auto
route-map SECONDARY permit 10
match ip address 150
set ip next-hop 12.x.x.129
access-list 101 permit tcp any host 12.x.x.135 eq ftp-data
access-list 150 permit ip host 172.18.0.x any
ip nat inside source static 172.18.0.145 12.x.x.135
Ryan Douglas
Why don't you no-nat it? Either adjust NAT AcL to deny, or create new acl and use it deny route map clause
