Fully functioning NAT on IOS, port forwarding
jacksonp2008
Community Member
This one has been bugging me (npi) as I believe I have it configured properly and it's a terribly simple use case.
Outside (10.2.234.x) --Router--(10.12.1.x) Inside
Outbound NAT works great with:
ip nat inside source list 1 interface GigabitEthernet0 overload
however, I also want to port forward inbound.  I have a secondary address on the outbound interface:
ip address 10.2.234.3 255.255.254.0 secondary
ip address 10.2.234.2 255.255.254.0
ip nat outside
ip nat enable
This seems to create the translations:
ip nat pool PRTFWD 10.12.1.62 10.12.1.62 netmask 255.255.255.0 type rotary
ip nat inside destination list 100 pool PRTFWD
Here is an example using port 80:
show ip nat tr
Pro Inside global         Inside local          Outside local         Outside global
tcp 10.2.234.3:80         10.12.1.62:80         10.10.120.119:64589   10.10.120.119:64589
tcp 10.2.234.3:80         10.12.1.62:80         10.10.120.119:64594   10.10.120.119:64594
So translations appear correct, but the host on browser 10.10.120.119 never gets a page back on port 80.
I must be missing something...  ideas?
Show IP nat translations shows that NAT is working correctly. You do not need the extendable at the end of the command. Please post your latest configuration so that I can take a look.
Your web server is on port 80 and also has default gateway which is 10.12.1.253. Correct?
Masoud
5 Replies 5
First, you need to correct your access-list
I do not see any access-list 1 in your configuration
And then for inbound port forwarding you need to use static NAT.
Something like this. Just add this line to your configuration
IP NAT inside source static tcp  [your real server address] [port] 10.12.1.62 80
And remove your destination nat
Hope it helps
Masoud
That does help Masoud, thank-you.
I must have dropped the ACL for outbound, working now.
My inbound is still not working however using static, here is what I have:
ip nat inside source static tcp 10.12.1.62 80 10.2.234.2 80 extendable
(10.12.1.62 is my real inside web server and it is answering on 80 )
(10.2.234.2 is the external interface address on my router)
It creates the translations:
tcp 10.2.234.2:80      10.12.1.62:80      10.10.120.80:64442 10.10.120.80:64442
tcp 10.2.234.2:80      10.12.1.62:80      10.10.120.80:64443 10.10.120.80:64443
tcp 10.2.234.2:80      10.12.1.62:80      ---                ---
But no data is passed...  , I tried a few other ports as well like ssh, etc.  any other ideas?
Masoud
Great!  If NAT is correct that's what I needed to know.
Note:  "extendable" is inserted by IOS, I did not add that.  Must be the default.
Thanks!!
You are most welcome.
