Bookmark
Subscribe
4093
Functionality of priority command under policy-map
John Blakley
All,
Taking the following into consideration:
policy-map TEST
     class TEST
          priority 768
The priority command guarantees at least 768, and I believe at most 768. The question that I have is if only 96k is needed for the above class, does it still set aside the 768k? If I have voice traffic that's matched for this class, and one person picks up the phone on a T1 circuit, does the router automatically set aside ALL 768 for that one phone call?
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello John,
there is a recent thread where the question has been widely discussed and tested
see
https://supportforums.cisco.com/thread/2016073?tstart=0
there is no policing action unless the link is congested, not used resources are available to other traffic classes:
so traffic of LLQ queue can be more then stated value in priority command if there are resources unused by other classes
CBWFQ with LLQ has this elasticity, older legacy queueing like priority queueing or custom queueing miss this capability.
When testing a CBWFQ scheduler there are output drops when the traffic mix volume is over 100% capacity of the link (taking in account max-bandwidth for platforms supporting it) and only classes over their value have drops providing effective differentiated services.
When the link is totally used, LLQ traffic is limited to stated priority value to avoid starvation on other queues (that happened in old Priority Queueing)
to be noted one could explicitly set a policer within the policy map and in that you could not go beyond stated value
Hope to help
Giuseppe
Giuseppe Larosa
Hello John,
see
Hope to help
Giuseppe
