Funky Behavior with my EIGRP IP Sumarization
PLC
Hi All,
I configured route summarization eigrp. When pinging the R2-destination from R1-source(two hops away)  it appears I have some sort of routing loop because I drop packets. I have attached my topology.  R1, R3, R2. R3 is in the middle with two interfaces one connected to R1 and the other to R2 so, I summarized in both interfaces. I appreciate your help in advance!
R1
int serial1/1
ip summary address 10.1.0.0 255.255.252.0
R3
int serial 1/1
ip summary address 10.2.0.0 255.255.252.0
int serial 1/0
R2
int s1/1
Hey plchacon1,
Can you include your EIGRP configuration and the outputs of "show ip route eigrp" for each router please?
yes of course..
R1#
R1#
R1#sho run | s eigrp
 ip summary-address eigrp 33 10.1.0.0 255.255.252.0 5
router eigrp 33
 network 10.1.1.0 0.0.0.255
 network 10.1.2.0 0.0.0.255
 network 10.1.3.0 0.0.0.255
 network 192.168.1.0
 no auto-summary
R1#sho ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/8 is variably subnetted, 8 subnets, 2 masks
C       10.1.3.0/24 is directly connected, Loopback2
D       10.3.0.0/22 [90/2809856] via 192.168.1.2, 04:40:37, Serial1/1
D       10.2.1.0/24 [90/2297856] via 192.168.1.2, 02:46:40, Serial1/1
C       10.1.2.0/24 is directly connected, Loopback1
D       10.2.2.0/24 [90/2297856] via 192.168.1.2, 02:46:40, Serial1/1
C       10.1.1.0/24 is directly connected, Loopback0
D       10.2.3.0/24 [90/2297856] via 192.168.1.2, 02:46:40, Serial1/1
D       10.1.0.0/22 is a summary, 04:42:39, Null0
C    192.168.1.0/24 is directly connected, Serial1/1
D    192.168.2.0/24 [90/2681856] via 192.168.1.2, 07:13:29, Serial1/1
R1#
R3#sho run | s eigrp
 ip summary-address eigrp 33 10.2.0.0 255.255.252.0 5
router eigrp 33
 network 10.2.1.0 0.0.0.255
 network 10.2.2.0 0.0.0.255
 network 10.2.3.0 0.0.0.255
 network 192.168.1.0
 network 192.168.2.0
 no auto-summary
R3#sho ip route
     10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
D       10.2.0.0/22 is a summary, 02:49:22, Null0
D       10.3.0.0/22 [90/2297856] via 192.168.2.2, 04:44:12, Serial1/0
C       10.2.1.0/24 is directly connected, Loopback0
C       10.2.2.0/24 is directly connected, Loopback1
C       10.2.3.0/24 is directly connected, Loopback2
D       10.1.0.0/22 [90/2297856] via 192.168.1.1, 04:46:16, Serial1/1
C    192.168.2.0/24 is directly connected, Serial1/0
R3#
R2#sho run | s eigrp
 ip summary-address eigrp 33 10.3.0.0 255.255.252.0 5
router eigrp 33
 network 10.3.1.0 0.0.0.255
 network 10.3.2.0 0.0.0.255
 network 10.3.3.0 0.0.0.255
 network 192.168.2.0
 no auto-summary
R2#sho ip route
C       10.3.1.0/24 is directly connected, Loopback0
D       10.2.0.0/22 [90/2297856] via 192.168.2.1, 02:47:51, Serial1/1
D       10.3.0.0/22 is a summary, 04:41:18, Null0
C       10.3.3.0/24 is directly connected, Loopback2
C       10.3.2.0/24 is directly connected, Loopback1
D       10.1.0.0/22 [90/2809856] via 192.168.2.1, 04:43:20, Serial1/1
D    192.168.1.0/24 [90/2681856] via 192.168.2.1, 07:14:07, Serial1/1
C    192.168.2.0/24 is directly connected, Serial1/1
R2#
