Funky NAT Pool
TODD BEERS
Level 2
Level 2
Trying to do a workaround for a SQL/application related problem. Per customer's security requirements, they're only using a single source IP for a single destination IP. The SQL/app problem is that while there are multiple connections from the same source IP, but with diferent source ports, the SQL/app end rejects more than one user when a query is issued. So I thought we could just NAT that single IP out to a pool and that would allow the destination to see multiple source IP's. Unfortunately, I haven't been able to get it to work yet, but then again, I haven't had to do a nat poll in a very long time. Here's what I've got:
int tunnel 8
ip nat inside
int vlan 10
ip addr 172.1.1.1
ip nat outside
ip route 10.22.78.0 255.255.255.0 172.1.1.2
ip nat pool Cust 10.22.78.10 10.22.78.100 netmask 255.255.255.0
ip nat outside source list Cust_out pool Cust add-route
access-list extended Cust_out
permit ip host 192.168.1.1 any
We also have another static NAT for the destination IP:
ip nat inside source static 10.22.80.53 172.22.80.53
VLAN10 is a LAN interface ni a DMZ.
Marwan ALshawi
What you do is to create a nat pool with same ip as starting and ending of the range
In nat command use overload keyword to make it like static nat and dynamic pat
Ip nat pool pool1 10.22.78.10 10.22.70.10 netmask 255.255.255.0
Access-list 100 permit ip host 192.168.1.1 any
Ip nat inside source list 100 pool pool1 overload
And make sure to remove the old nat config and the source interface has ip nat onside and the outgoing interface has ip nat outside
Hope this help
