G.722 Vs. G.711
Brent Rockburn
Level 2
Level 2
I know this isn't the place for this but similar questions asked in the VOIP forum were never answered.
I was wondering if you guys have an docs outlining the difference/improvements in g.722 as oppose to g.711 if any.
Brent
Hi, I don't think there's any CISCO document with all the details,
but you can take a look to :
http://www.broadcom.com/support/broadvoice/codec_comparison.php
In this whitepaper you can find some other details about this codec.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8537/prod_white_paper0900aecd806fa57a.html
Please note that the codec to use depends on your goal:
http://www.dspdesignline.com/howto/201000337
Offering wideband voice is a great way to ensure the best possible quality of experience for users of VoIP equipment such as IP phones. IP phone and VoIP system designers may wish to choose from the following classes of codecs, depending on the most important system-design constraints:
Narrowband:
    * G.711, G.726: Offers narrow-band voice with low processing requirements, and with typical bit-rates of 32-64 kbps.
    * Other narrow-band codecs with compression, such as G.729AB and G.723.1, offer bit-rates as low as 5.3 kbps, but require higher DSP processing horsepower.
Wideband:
    * G.722: Offers wideband voice with low DSP processing requirement similar to standard G.726 ADPCM. However, it requires a bit-rate of 48-64 kbps per channel.
    * G.722.2: Offers wideband voice and compresses the bandwidth down to 12.65 kbps per channel. The trade-off is that it requires more processing cycles than G.722.
regards
Yesua
