Gateway obtaining issue with DHCP.
Farazahmed786
Hi, I need help as i am facing below issue with DHCP:
In Inter-VLAN routing environment hosts in different VLANs gets IP address from DHCP successfully, while hosts in same VLAN (same VLAN where DHCP resides ) gets IP addresses, subnet mask and DNS information but unable to get Default Gateway.
Packet Tracer file is attached.
Hello
Looks like all you need to do is change your dhcp scopes a little.
serverPool = Set all values to zero
Lan1-2 = Start ip address not to include D/G addresss
Save these changes and test again.
Kind Regards
Paul
Hello
Kind Regards
Paul
Thanks you So Much Paul,
Issue resolved with "serverPool = Set all values to zero".
