11-11-2019 06:58 AM
Hi All, I have a C1111-8P with SL-1100-8P-SEC & FL-VPERF-8P-200. The licenses were ordered as part of the router configuration and not as spares. As far as I know these licenses are not SMART licenses. Can I just disable smart licensing and the licenses will go back to normal without the need to register?
RTR#show license sum
Smart Licensing is ENABLED
Registration:
Status: UNREGISTERED
Export-Controlled Functionality: NOT ALLOWED
License Authorization:
Status: EVAL MODE
Evaluation Period Remaining: 88 days, 23 hours, 32 minutes, 35 seconds
License Usage:
License Entitlement tag Count Status
(ISR_1100_8P_Security) 1 EVAL MODE
(ISR_1100_8P_IPSEC_Thro...) 1 EVAL MODE
Solved! Go to Solution.
11-12-2019 01:06 PM
11-11-2019 01:12 PM
11-11-2019 01:42 PM
Thanks Leo. Can I disable smart licensing or will I have to both downgrade and disable smart licensing?
11-11-2019 02:14 PM
11-12-2019 06:07 AM
It's on Version 16.10.01b
11-12-2019 01:06 PM
11-13-2019 10:46 AM
Smart licensing is mandatory unfortunately for any router running 16.10.x and up and any switch running 16.8.x and up.
I would use 16.9.4, this is a very stable release at the time of writing this with no smart licensing need.
Cisco is really screwing us over with the mandatory "smart" licensing, trying to get every last dollar out of the customer :-(
