Gateway of last resort
thepxjx
Hi, I am having trouble pinging the DNS server from anywhere in the network. I think it has something to do with the gateway of last resort on both routers. Any help would be much appreciated.
the most important issue was that the GigabitEthernet0/0 interface on your JSRT1 router had no IP address at all, so there was no external connectivity. Also, on both routers, there were a lot of redundant, unnecessary static routes.
I added the IP address to the interface, removed the static routes, and added just the routes that are necessary. The DNS server is now reachable from anywhere.
Review the attached, revised file.
10 Replies 10
balaji.bandi
If the Server in outside the network and on the internet, your JTSR1 should do the NAT to reach Internet IP
what is the IP address of DNS ? from what IP source are you trying to reach.
Traceroute is a good tool to see where the last packet from, that is the point you start doing troubleshooting.
BB
The DNS IP is 10.10.10.2 , and am trying to reach from the 192.168.64.0 network will have a look at the traceroute and get back to you, thanks
chenmel
I'm going to see what other people are suggesting in this thread, but I do remember my professor saying something to me when I asked her about gateway of last resort and key command strings to be mindful of using in sequence from each router's command line interface to get the network humming harmoniously and buzzing productively. She said that after configuring the IP addresses of the interface ports on routers and switches to execute the no shutdown command and engage encryption on the respective levels of executive command input modes. I hope that makes sense and that it also helps you to resolve the issue you've posted. Have a great day, fellow Cisco end user! Hope to chat more with you or anybody here soon on Microsoft Teams about any ideas, thoughts, or solutions for hiccups we might run into as we continue to develop our networking skills and master this wonderful means of connecting the communications of people all over the world. ^__^ Here's an invite link to my Cosmiknight profile's chat room (See yawl soon!) : https://teams.live.com/l/invite/FAAbIKYLYia53IKOwE
NLC, PTK PRO, SA&VE
Hello
Post the PT file if applicable.
Kind Regards
Paul
Here is the .pkt file in a zip file
Good morning Georg,
Would you be willing to post a step-by-step walkthrough of how you took the initial .pkt file provided by OP and brought it to the state of resolution you provided in your reply? I would like to follow up on such a list with screenshots as I recreate the process you just described and get results that will hopefully match up with your packet tracer experience.
Respectfully,
Chen Mel
NLC, PTK PRO, SA&VE
I did not take any screenshots unfortunately. But the solution is/was fairly simple. GigabitEthernet0/0 had no IP address at all, so you just have to add one. Then all you need is a static default route pointing towards 1.1.1.1, and a specific route towards the local network connected to the other router. On the other router, all you need is a static default route towards the right router. Take out all the other routes.
Wow thanks George, must of overlooked GigabitEthernet 0/0
Hello
Please see attached working PT using an IGP (eigrp).
Notes:
  • Removed all static routes not required from both rtrs
  • Enabled eigrp on jtsr1 & hwsr1 rtrs
  • Added two specific static routes on jtsr1 rtr for the dns server and internal wifi networks then redistributed into eigrp
  • Fixed dhcp for wifi internal network
Kind Regards
Paul
