Gateway to internet
wgranada1
I confused myself here...my last hop before I hit my ISP is 198.168.96.2 the router that I'm on has a Gateway of last resort of 172.19.207.5 which is the ethernet interface on my core router. Now question is if someone needed a gateway to point to to get to the internet I would give him the IP address of the last hop router before it hits the ISP, which in my case is the 198.168.96.2 correct? Sorry for the silly question.....thank you in advance
foxbatreco
Level 3
Level 3
For connections from your router, u have to gateway as the connected interface ip address that the users are attached to.
Say,ethernet interface ip for users connected on this router and the router will carry them to internet with the default route in there.
HTH!!!!
ok so what you are saying is that I would need to use the next hop router as the gateway
so for instance:
rt1 rt2 rt5 -> internet
so if I'm on rt1 and I want to point folks to the gateway that leads to the inter net I would have to give them the next hop router interface in this case it would be rt2's interface and then rt2 would know how to get to the internet right??
