Gathering CBQoSMIB rate values for sub-classes
jpmanrique
PLATFORM: Cisco 827H.I am trying to control bw occupation per service but sharing the same class. For that, I have created a class which gather several classes:
class-map match-any PLATA
match class-map SERVICE1
match class-map SERVICE2
match class-map SERVICE3
match class-map SERVICE4
From the CLI we can obtain rates for each sub-class through 'show policy-map interface' command. However, ciscoCBQosMIB does not offer the rate per sub-class, only for the major hierarchy classes in the policy-map. I have loaded the IOS 12.3(14)T2 but the behavior is the same. Any recommendation or suggest will be greatly welcomed.
b.hsu
Level 5
Level 5
Did you try "show policy-map class ", check the following link for more options on the "show policy-map" command :
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_command_reference_chapter09186a008017cf12.html#wp1144083
