GE T SFP CISCO vs CISCO-METHODE
johnlloyd_13
Level 9
Level 9
hi,
i've received a mix of plastic (bright yellow) and metal (gold) GE T SFPs and used them on ASR1001-x.
the 'CISCO' SFP on ASR-2 works perfect but i got the link between ASR-1 and N3K switch UP using 'CISCO-METHODE' after hardcoding negotation, speed, and duplex settings BUT getting a very small increment CRC errors on the N3K side.
there's no CRC errors on the ASR1side
ASR-1#sh int g0/0/1
GigabitEthernet0/0/1 is up, line protocol is up
  Hardware is BUILT-IN-2T+6X1GE, address is 00fc.bab6.1234 (bia 00fc.bab6.1234)
  Description: Eth1/11
  Internet address is 1.2.3.4/27
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 157/255, rxload 158/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is force-up, media type is T
  output flow-control is on, input flow-control is on
  Last input 00:00:00, output 00:00:03, output hang never
  Last clearing of "show interface" counters 3w0d
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 61984000 bits/sec, 13460 packets/sec
  30 second output rate 61955000 bits/sec, 13435 packets/sec
     462652296 packets input, 254086241871 bytes, 0 no buffer
     Received 11533 broadcasts (0 IP multicasts)
     0 watchdog, 110382 multicast, 0 pause input
     460940740 packets output, 253736175337 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     2260 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
N3K-1# sh int e1/11
Ethernet1/11 is up
 Dedicated Interface
  Hardware: 10/100/1000 Ethernet, address: e4c7.22c0.1234 (bia e4c7.22c0.1234)
  Description: ASR1
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
  Encapsulation ARPA
  Port mode is access
  full-duplex, 1000 Mb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 11:50:25
  Last clearing of "show interface" counters 02:04:28
  0 interface resets
  30 seconds input rate 53631800 bits/sec, 12170 packets/sec
  30 seconds output rate 53666984 bits/sec, 12201 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 51.96 Mbps, 11.87 Kpps; output rate 51.99 Mbps, 11.90 Kpps
  RX
    93094489 unicast packets  8285 multicast packets  3110 broadcast packets
    93105996 input packets  50908204410 bytes
    0 jumbo packets  0 storm suppression bytes
    0 runts  0 giants  112 CRC  0 no buffer
    112 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    93284129 unicast packets  18482 multicast packets  1818 broadcast packets
    93304429 output packets  50937193987 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble 0 output discard
    0 Tx pause
i'm unable to remove the SFP since it's in a production and only able to issue 'sh hw-module transceiver' commands. cable and SFP were already swapped and suspect i got a bad batch of SFP or third party ones.
can someone advise if there's compatibility issue on GE T SFP between ASR and N3K?
is CISCO-METHODE a non-genuine SFP?
how can i tell without removing from the chassis? any other show commads i can use?
ASR-1#sh hw-module int g0/0/1 transceiver idprom brief
IDPROM for transceiver GigabitEthernet0/0/1:
  Description                               = SFP or SFP+ optics (type 3)
  Transceiver Type:                         = GE T (26)
  Product Identifier (PID)                  = SP7041-E
  Vendor Revision                           = E
  Serial Number (SN)                        = MTC18291234
  Vendor Name                               = CISCO-METHODE
  Vendor OUI (IEEE company ID)              = 00.00.00 (0)
  CLEI code                                 = N/A
  Cisco part number                         = N/A
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 14/07/21
  Connector type                            = Unknown.
  Encoding                                  = 8B10B
                                              NRZ
  Nominal bitrate                           = GE (1300 Mbits/s)
  Minimum bit rate as % of nominal bit rate = not specified
  Maximum bit rate as % of nominal bit rate = not specified
ASR-2#sh hw-module int g0/0/1 transceiver idprom brief
  Product Identifier (PID)                  = SP7041-TE
  Vendor Revision                           = A1
  Serial Number (SN)                        = MTC21214567
  Vendor Name                               = CISCO
  Vendor OUI (IEEE company ID)              = 00.17.05 (5893)
  CLEI code                                 = CMUIAGBCAA
  Cisco part number                         = 30-1475-01
  Date code (yy/mm/dd)                      = 17/06/07
  Encoding                                  = 8B10B
                                              NRZ
0 Replies 0
