09-24-2021 12:02 PM
I have looked into a couple of older forums which lists different MIBS and OID though which this can be achieved but all those are old OIDs which I cant get it to work on the newer Catalyst 9200L switch or 3650 series.
We have a remote switch for which started rejecting SSH connections after the OS update to 16.12.5b
No issues with the normal functioning of the device, SNMP works too. We tried rebooting the device, issue still persists.
We are looking to zero size the existing SSH keys on the switch and generate new keys and hope that this will fix the SSH connection issue.
Does anyone know how can this be achieved on newer Catalyst switches.
09-24-2021 03:18 PM
yes it should be, you looking this proceedure ?
connect console cable and config mode :
configure terminal
crypto key zeroize rsa
crypto key generate rsa modulus 2048
09-27-2021 05:14 AM
Hi Balaji,
Thank you for the reply. I would have connected the console cable to the switch if I could get my hands on it.
The issues is, currently the switch is at a remote unmanned location. SSH isn't working but SNMP is, so I read a lot of forums which mention its possible to reboot and make config changes via snmp. So if I can send some commands using snmp I can re-generate the SSH Keys. Unfortunately when I tried the SNMP walk, it wasn't responding the the MIB required to make config changes. I was able to reboot the switch using SNMP because we have the snmp-server system-shutdown enabled. There might be a way to achieve this using SNMP. Below is some of the articles that I have read and tried but due to lack of my experience, I am not able to figure this one out.
Even if its possible to enable telnet using SNMP, I can telnet to the switch and regenerate the the keys.
How To Copy Configurations To and From Cisco Devices Using SNMP - Cisco
NetMRI use SNMP SetRequest to enable telnet on a d... - Infoblox Experts Community
09-27-2021 06:05 AM
I am thinking, maybe you can generate the keys on another device, and then copy the new configuration to the switch using SNMP. I remember somebody copying the config file using SNMP, have a look at the thread below...
https://community.cisco.com/t5/switching/copy-config-out-from-switch-via-snmp-fails/td-p/3067668
09-28-2021 06:32 AM - edited 09-28-2021 06:32 AM
Thank you Georg for your reply, I tried using the snmpwrite to copy config using MIBs mentioned in the link.
It returns "No such Instance currently exists at this OID"
MIBs tried and tested are below
.1.3.6.1.4.1.9.9.96.1.1.1.1.2.52
.1.3.6.1.4.1.9.9.96.1.1.1.1.10
.1.3.6.1.4.1.9.2.1.53
They all return the same error "No Such Instance currently exists at this OID"
09-24-2021 03:22 PM
To be honest, I do not believe that it is possible to use SNMP to zeroize and recreate the SSH keys on your switch. I do not believe there are dedicated OIDs for the keys themselves, and the OIDs for copying the entire configuration to and from the switch probably aren't useful either because the crypto key zeroize and crypto key generate commands are interactive and not stored in the running-config, meaning that they are unlikely to be accepted from a copied configuration.
I would like to understand more about what happened after the update, though: What is exactly the symptom with the failing SSH? Is the TCP port 22 on the switch entirely closed? Or is it open but does not speak SSH at all? Does it terminate the connection prematurely? Can you actually try to connect via SSH to your switch once again, preferably using a Linux-based command line ssh client with the -v switch (i.e. ssh -v login@X.X.X.X) to get the verbose output, and share it here so that we have a more detailed insight what is going on with the SSH support on the switch?
Also, how about alternative access to the switch - Telnet, HTTP(S), console? Surely at least the console should be still available - even if it requires physical access to the switch.
Best regards,
Peter
09-27-2021 05:51 AM
Hi Peter,
Thank you for the reply. Actually I want to achieve zero size and generate the RSA key and according to one of the article Conf T via SNMP (neverthenetwork.com) we can create the ssh keys via snmp. Until last week I didn't know it was possible to reboot the switch with SNMP and I had to add a line snmp-server system shutdown to be able to do that. We do not have telnet enabled on the switch so I am trying to get atleast config T working using snmp,if that works I can enable telnet on the remote switch and re-generate the SSH keys. NetMRI use SNMP SetRequest to enable telnet on a d... - Infoblox Experts Community
As for after the update, the device rebooted and we were not able to ssh to it. We copied the file and installed the update over ssh but not sure what happened after the update. Also to note, it was a significant firmware update as we went from base version to 16.4.2. I tried looking into generating a log file with verbose output, the ssh client receives the message "Connection Refused" as soon as I try to ssh, not so helpful logs from putty, linux machine or powershell.
Our last option is console but the switch is at an unmanned location, someone has to go to the site and connect to console cable for us to remotely connect to their computer and access the switch via console cable. For now we can consider doing that but for future if we can achieve this over SNMP then it would be a good alternative to driving all the way to a mountain site just to enable ssh. Switch is doing its job so the production is not affected but its a remote site.
Hitesh
09-27-2021 07:03 AM
>.... to driving all the way to a mountain site just to enable...
In theory you can use the CISCO-COPY-CONFIG-MIB to integrate/merge configuration-snippets in the running config with snmp (write) through scripting , for instance for enabling telnet. It might be possible for rsa-keys too , not sure if that can work. Anyway this requires that the current snmp-write community for the device is known and not restricted by access for/from your intended snmp-manager.
Or otherwise it's time to get the hiking-boots (smiley noted).
M.
09-28-2021 06:31 AM
Thank you Marcee for your reply, I tried using the snmpwrite to copy config using MIBs mentioned in the link.
09-28-2021 08:45 AM
- It's unclear what you tried from that example and or the output seems a bit too sparse. First of all you speak of MIBs tried but there is only one MIB involved in the process which is the CISCO-COPY-CONFIG-MIB. From the document I send you earlier it is better to use the named OID's instead of the numeric ones. Further more the needed sequence and or snmp-set command-sequence is much more elaborated and initiates which setting a sources file , instructing the transfer , and some cleanup afterwards. You could for instance google on 'cisco copy-config-mib script example' to get some examples. Here is an interesting one : https://gist.github.com/tomoconnor/6425476
It could be used as a test to fetch the configuration from the switch , of course a number of parameters must be changed, such as the address of the collecting tftp-server and the (ultimate) destination file. If that would work, the script is easily adaptable to do the reverse. Note that is not required to upload a complete config to the switch , configuration-snippets can be uploaded too and they will not overwrite the rest of the running configuration.
M.
Original ref : https://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/15217-copy-configs-snmp.html
