Get a switch on the internet through another switch that is connected to the internet.
mikerocom1
I have made a few changes and added a cisco 2811 and a cable modem. i am able to ping out from the 2811 but not the 4507. I can ping the default gateway of 172.16.110.4 but nothing beyond that.
5/24 on the switch is the trunk to the router.
Router:
ValpMgt#sho run
Building configuration...
Current configuration : 1319 bytes
version 12.4
hostname ValpMgt
boot-start-marker
boot-end-marker
no logging console
enable secret 5 $1$IdtM$iH4dPWQW045SUD1PLTJs01
no aaa new-model
ip cef
ip dhcp use vrf connected
ip dhcp excluded-address 172.16.110.1 172.16.110.50
ip dhcp excluded-address 172.16.110.100 172.16.110.150
ip dhcp pool MANAGMENT
   import all
   network 172.16.110.0 255.255.255.0
   default-router 172.16.110.4
   dns-server 204.49.178.17 8.8.8.8
username admin password 0 valPower
ip ssh version 2
interface FastEthernet0/0
 description WAN
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
interface FastEthernet0/1
 description LAN
 no ip address
 ip nat inside
 duplex auto
 speed auto
interface FastEthernet0/1.10
 encapsulation dot1Q 10
 ip address 172.16.110.4 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
no ip http server
no ip http secure-server
ip nat inside source list 101 interface FastEthernet0/0 overload
access-list 101 permit ip 172.16.110.0 0.0.0.255 any
control-plane
line con 0
 password valPower
 login
line aux 0
line vty 0 4
 login local
 transport input ssh
scheduler allocate 20000 1000
end
ValpMgt#sho ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            204.49.184.14   YES DHCP   up                    up
FastEthernet0/1            unassigned      YES manual up                    up
FastEthernet0/1.10         172.16.110.4    YES manual up                    up
NVI0
Switch:
valp01#sho run
Current configuration : 18075 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service compress-config
hostname valp01
boot-start-marker
boot-end-marker
redundancy
 mode sso
enable secret 5 $1$uR52$q/5XhKRQ4.vvd7s2zW/vZ0
username admin secret 5 $1$zNnW$Tovtm9bNNAk2xjYmBNxse0
no aaa new-model
ip subnet-zero
ip domain-name valp.net
ip multicast-routing
ip ssh version 2
no file verify auto
spanning-tree mode pvst
power redundancy-mode redundant
vlan internal allocation policy ascending
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet2/1
interface GigabitEthernet2/2
interface GigabitEthernet3/1
 shutdown
interface GigabitEthernet3/2
 shutdown
interface GigabitEthernet3/3
 shutdown
interface GigabitEthernet3/4
 shutdown
interface GigabitEthernet3/5
 shutdown
interface GigabitEthernet3/6
 shutdown
interface GigabitEthernet3/7
 shutdown
interface GigabitEthernet3/8
 shutdown
interface GigabitEthernet3/9
 shutdown
interface GigabitEthernet3/10
 shutdown
interface GigabitEthernet3/11
 shutdown
interface GigabitEthernet3/12
 shutdown
interface GigabitEthernet3/13
 shutdown
interface GigabitEthernet3/14
 shutdown
interface GigabitEthernet3/15
 shutdown
interface GigabitEthernet3/16
 shutdown
interface GigabitEthernet3/17
 shutdown
interface GigabitEthernet3/18
 shutdown
interface GigabitEthernet4/1
 description DM1 MANAGEMENT
 switchport access vlan 10
 switchport mode access
interface GigabitEthernet4/2
 description DM2 MANAGEMENT
interface GigabitEthernet4/3
 description DM3 MANAGEMENT
interface GigabitEthernet4/4
 description DM4 MANAGEMENT
interface GigabitEthernet4/5
 description APEX MANAGEMENT
interface GigabitEthernet4/6
interface GigabitEthernet4/7
interface GigabitEthernet4/8
interface GigabitEthernet4/9
interface GigabitEthernet4/10
interface GigabitEthernet4/11
interface GigabitEthernet4/12
interface GigabitEthernet4/13
interface GigabitEthernet4/14
interface GigabitEthernet4/15
interface GigabitEthernet4/16
interface GigabitEthernet4/17
interface GigabitEthernet4/18
interface GigabitEthernet4/19
interface GigabitEthernet4/20
interface GigabitEthernet4/21
interface GigabitEthernet4/22
interface GigabitEthernet4/23
interface GigabitEthernet4/24
interface GigabitEthernet4/25
interface GigabitEthernet4/26
interface GigabitEthernet4/27
interface GigabitEthernet4/28
interface GigabitEthernet4/29
interface GigabitEthernet4/30
interface GigabitEthernet4/31
 shutdown
interface GigabitEthernet4/32
 shutdown
interface GigabitEthernet4/33
 shutdown
interface GigabitEthernet4/34
 shutdown
interface GigabitEthernet4/35
 shutdown
interface GigabitEthernet4/36
 shutdown
interface GigabitEthernet4/37
 shutdown
interface GigabitEthernet4/38
 shutdown
interface GigabitEthernet4/39
 shutdown
interface GigabitEthernet4/40
 shutdown
interface GigabitEthernet4/41
interface GigabitEthernet4/42
interface GigabitEthernet4/43
 shutdown
interface GigabitEthernet4/44
interface GigabitEthernet4/45
 switchport trunk native vlan 10
 switchport mode trunk
interface GigabitEthernet4/46
 description UPLINK TO EDGE
interface GigabitEthernet4/47
 shutdown
interface GigabitEthernet4/48
 description VLAN SERVER
interface GigabitEthernet5/1
 description APEX VIDEO
 switchport access vlan 20
interface GigabitEthernet5/2
 description DM1 GIGE E1
interface GigabitEthernet5/3
 description DM2 GIGE E1
interface GigabitEthernet5/4
 description DM3 GIGE E1
interface GigabitEthernet5/5
 description DM3 GIGE D1
interface GigabitEthernet5/6
interface GigabitEthernet5/7
interface GigabitEthernet5/8
interface GigabitEthernet5/9
interface GigabitEthernet5/10
interface GigabitEthernet5/11
interface GigabitEthernet5/12
interface GigabitEthernet5/13
interface GigabitEthernet5/14
interface GigabitEthernet5/15
interface GigabitEthernet5/16
interface GigabitEthernet5/17
interface GigabitEthernet5/18
interface GigabitEthernet5/19
interface GigabitEthernet5/20
interface GigabitEthernet5/21
interface GigabitEthernet5/22
interface GigabitEthernet5/23
interface GigabitEthernet5/24
interface GigabitEthernet6/1
 description multicast_port
interface GigabitEthernet6/2
interface GigabitEthernet6/3
 shutdown
interface GigabitEthernet6/4
 shutdown
interface GigabitEthernet6/5
 shutdown
interface GigabitEthernet6/6
 shutdown
interface GigabitEthernet6/7
 shutdown
interface GigabitEthernet6/8
 shutdown
interface GigabitEthernet6/9
 shutdown
interface GigabitEthernet6/10
 shutdown
interface GigabitEthernet6/11
 shutdown
interface GigabitEthernet6/12
 shutdown
interface GigabitEthernet6/13
 shutdown
interface GigabitEthernet6/14
 shutdown
interface GigabitEthernet6/15
 shutdown
interface GigabitEthernet6/16
 shutdown
interface GigabitEthernet6/17
 shutdown
interface GigabitEthernet6/18
 shutdown
interface GigabitEthernet6/19
 shutdown
interface GigabitEthernet6/20
 shutdown
interface GigabitEthernet6/21
 shutdown
interface GigabitEthernet6/22
 shutdown
interface GigabitEthernet6/23
 shutdown
interface GigabitEthernet6/24
 shutdown
interface GigabitEthernet6/25
 shutdown
interface GigabitEthernet6/26
 shutdown
interface GigabitEthernet6/27
 shutdown
interface GigabitEthernet6/28
 shutdown
interface GigabitEthernet6/29
 shutdown
interface GigabitEthernet6/30
 shutdown
interface GigabitEthernet6/31
 shutdown
interface GigabitEthernet6/32
 shutdown
interface GigabitEthernet6/33
 shutdown
interface GigabitEthernet6/34
 shutdown
interface GigabitEthernet6/35
 shutdown
interface GigabitEthernet6/36
 shutdown
interface GigabitEthernet6/37
 shutdown
interface GigabitEthernet6/38
 shutdown
interface GigabitEthernet6/39
 shutdown
interface GigabitEthernet6/40
 shutdown
interface GigabitEthernet6/41
 shutdown
interface GigabitEthernet6/42
 shutdown
interface GigabitEthernet6/43
 shutdown
interface GigabitEthernet6/44
 shutdown
interface GigabitEthernet6/45
 shutdown
interface GigabitEthernet6/46
 shutdown
interface GigabitEthernet6/47
 shutdown
interface GigabitEthernet6/48
 shutdown
interface GigabitEthernet7/1
 description HITS DATA
 spanning-tree portfast
interface GigabitEthernet7/2
 switchport access vlan 11
interface GigabitEthernet7/3
interface GigabitEthernet7/4
interface GigabitEthernet7/5
interface GigabitEthernet7/6
interface GigabitEthernet7/7
interface GigabitEthernet7/8
interface GigabitEthernet7/9
interface GigabitEthernet7/10
interface GigabitEthernet7/11
interface GigabitEthernet7/12
interface GigabitEthernet7/13
interface GigabitEthernet7/14
interface GigabitEthernet7/15
interface GigabitEthernet7/16
interface GigabitEthernet7/17
interface GigabitEthernet7/18
interface GigabitEthernet7/19
interface GigabitEthernet7/20
interface GigabitEthernet7/21
interface GigabitEthernet7/22
interface GigabitEthernet7/23
 description TO JUNIPER NETSCREEN
interface GigabitEthernet7/24
 description UPLINK TO MAIN SWITCH
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 172.16.110.1 255.255.255.0
interface Vlan11
 no ip address
interface Vlan20
 ip address 172.16.120.2 255.255.255.0
 ip pim sparse-dense-mode
 ip igmp join-group 239.252.150.1
 ip igmp join-group 239.252.150.2
 ip igmp join-group 239.252.150.3
 ip igmp join-group 239.252.150.4
 ip igmp join-group 239.252.150.5
 ip igmp join-group 239.252.150.6
 ip igmp join-group 239.252.150.7
 ip igmp join-group 239.252.150.8
 ip igmp join-group 239.252.150.9
interface Vlan21
 ip address 172.16.121.2 255.255.255.0
 ip igmp join-group 239.252.151.1
interface Vlan22
 ip address 172.16.122.2 255.255.255.0
interface Vlan23
 ip address 172.16.123.2 255.255.255.0
ip default-gateway 172.16.110.1
ip http server
ip pim ssm default
line con 0
 password 7 0012120A34541C031D
 logging synchronous
 login
 stopbits 1
line vty 0 4
 logging synchronous
 login local
 transport input telnet ssh
line vty 5 15
 logging synchronous
 login local
end
valp01#sho ip int br
Vlan1                  unassigned      YES manual administratively down down
Vlan10                 172.16.110.1    YES NVRAM  up                    up
Vlan11                 unassigned      YES manual up                    up
Vlan20                 172.16.120.2    YES manual up                    up
Vlan21                 172.16.121.2    YES manual up                    up
Vlan22                 172.16.122.2    YES manual up                    up
Vlan23                 172.16.123.2    YES manual up                    up
GigabitEthernet1/1     unassigned      YES unset  down                  down
GigabitEthernet1/2     unassigned      YES unset  down                  down
GigabitEthernet2/1     unassigned      YES unset  down                  down
GigabitEthernet2/2     unassigned      YES unset  down                  down
GigabitEthernet3/1     unassigned      YES unset  administratively down down
GigabitEthernet3/2     unassigned      YES unset  administratively down down
GigabitEthernet3/3     unassigned      YES unset  administratively down down
GigabitEthernet3/4     unassigned      YES unset  administratively down down
GigabitEthernet3/5     unassigned      YES unset  administratively down down
GigabitEthernet3/6     unassigned      YES unset  administratively down down
GigabitEthernet3/7     unassigned      YES unset  administratively down down
GigabitEthernet3/8     unassigned      YES unset  administratively down down
GigabitEthernet3/9     unassigned      YES unset  administratively down down
GigabitEthernet3/10    unassigned      YES unset  administratively down down
GigabitEthernet3/11    unassigned      YES unset  administratively down down
GigabitEthernet3/12    unassigned      YES unset  administratively down down
GigabitEthernet3/13    unassigned      YES unset  administratively down down
GigabitEthernet3/14    unassigned      YES unset  administratively down down
GigabitEthernet3/15    unassigned      YES unset  administratively down down
GigabitEthernet3/16    unassigned      YES unset  administratively down down
GigabitEthernet3/17    unassigned      YES unset  administratively down down
GigabitEthernet3/18    unassigned      YES unset  administratively down down
GigabitEthernet4/1     unassigned      YES unset  up                    up
GigabitEthernet4/2     unassigned      YES unset  up                    up
GigabitEthernet4/3     unassigned      YES unset  up                    up
GigabitEthernet4/4     unassigned      YES unset  down                  down
GigabitEthernet4/5     unassigned      YES unset  up                    up
GigabitEthernet4/6     unassigned      YES unset  up                    up
GigabitEthernet4/7     unassigned      YES unset  up                    up
GigabitEthernet4/8     unassigned      YES unset  up                    up
GigabitEthernet4/9     unassigned      YES unset  down                  down
GigabitEthernet4/10    unassigned      YES unset  down                  down
GigabitEthernet4/11    unassigned      YES unset  up                    up
GigabitEthernet4/12    unassigned      YES unset  up                    up
GigabitEthernet4/13    unassigned      YES unset  down                  down
GigabitEthernet4/14    unassigned      YES unset  down                  down
GigabitEthernet4/15    unassigned      YES unset  down                  down
GigabitEthernet4/16    unassigned      YES unset  down                  down
GigabitEthernet4/17    unassigned      YES unset  up                    up
GigabitEthernet4/18    unassigned      YES unset  up                    up
GigabitEthernet4/19    unassigned      YES unset  up                    up
GigabitEthernet4/20    unassigned      YES unset  up                    up
GigabitEthernet4/21    unassigned      YES unset  up                    up
GigabitEthernet4/22    unassigned      YES unset  up                    up
GigabitEthernet4/23    unassigned      YES unset  up                    up
GigabitEthernet4/24    unassigned      YES unset  up                    up
GigabitEthernet4/25    unassigned      YES unset  up                    up
GigabitEthernet4/26    unassigned      YES unset  up                    up
GigabitEthernet4/27    unassigned      YES unset  up                    up
GigabitEthernet4/28    unassigned      YES unset  up                    up
GigabitEthernet4/29    unassigned      YES unset  up                    up
GigabitEthernet4/30    unassigned      YES unset  up                    up
GigabitEthernet4/31    unassigned      YES unset  administratively down down
GigabitEthernet4/32    unassigned      YES unset  administratively down down
GigabitEthernet4/33    unassigned      YES unset  administratively down down
GigabitEthernet4/34    unassigned      YES unset  administratively down down
GigabitEthernet4/35    unassigned      YES unset  administratively down down
GigabitEthernet4/36    unassigned      YES unset  administratively down down
GigabitEthernet4/37    unassigned      YES unset  administratively down down
GigabitEthernet4/38    unassigned      YES unset  administratively down down
GigabitEthernet4/39    unassigned      YES unset  administratively down down
GigabitEthernet4/40    unassigned      YES unset  administratively down down
GigabitEthernet4/41    unassigned      YES unset  up                    up
GigabitEthernet4/42    unassigned      YES unset  up                    up
GigabitEthernet4/43    unassigned      YES unset  administratively down down
GigabitEthernet4/44    unassigned      YES unset  up                    up
GigabitEthernet4/45    unassigned      YES unset  up                    up
GigabitEthernet4/46    unassigned      YES unset  up                    up
GigabitEthernet4/47    unassigned      YES unset  administratively down down
GigabitEthernet4/48    unassigned      YES unset  up                    up
GigabitEthernet5/1     unassigned      YES unset  down                  down
GigabitEthernet5/2     unassigned      YES unset  down                  down
GigabitEthernet5/3     unassigned      YES unset  down                  down
GigabitEthernet5/4     unassigned      YES unset  down                  down
GigabitEthernet5/5     unassigned      YES unset  down                  down
GigabitEthernet5/6     unassigned      YES unset  down                  down
GigabitEthernet5/7     unassigned      YES unset  down                  down
GigabitEthernet5/8     unassigned      YES unset  down                  down
GigabitEthernet5/9     unassigned      YES unset  down                  down
GigabitEthernet5/10    unassigned      YES unset  down                  down
GigabitEthernet5/11    unassigned      YES unset  down                  down
GigabitEthernet5/12    unassigned      YES unset  down                  down
GigabitEthernet5/13    unassigned      YES unset  down                  down
GigabitEthernet5/14    unassigned      YES unset  down                  down
GigabitEthernet5/15    unassigned      YES unset  down                  down
GigabitEthernet5/16    unassigned      YES unset  down                  down
GigabitEthernet5/17    unassigned      YES unset  down                  down
GigabitEthernet5/18    unassigned      YES unset  down                  down
GigabitEthernet5/19    unassigned      YES unset  down                  down
GigabitEthernet5/20    unassigned      YES unset  down                  down
GigabitEthernet5/21    unassigned      YES unset  down                  down
GigabitEthernet5/22    unassigned      YES unset  down                  down
GigabitEthernet5/23    unassigned      YES unset  down                  down
GigabitEthernet5/24    unassigned      YES unset  up                    up
GigabitEthernet6/1     unassigned      YES unset  down                  down
GigabitEthernet6/2     unassigned      YES unset  down                  down
GigabitEthernet6/3     unassigned      YES unset  administratively down down
GigabitEthernet6/4     unassigned      YES unset  administratively down down
GigabitEthernet6/5     unassigned      YES unset  administratively down down
GigabitEthernet6/6     unassigned      YES unset  administratively down down
GigabitEthernet6/7     unassigned      YES unset  administratively down down
GigabitEthernet6/8     unassigned      YES unset  administratively down down
GigabitEthernet6/9     unassigned      YES unset  administratively down down
GigabitEthernet6/10    unassigned      YES unset  administratively down down
GigabitEthernet6/11    unassigned      YES unset  administratively down down
GigabitEthernet6/12    unassigned      YES unset  administratively down down
GigabitEthernet6/13    unassigned      YES unset  administratively down down
GigabitEthernet6/14    unassigned      YES unset  administratively down down
GigabitEthernet6/15    unassigned      YES unset  administratively down down
GigabitEthernet6/16    unassigned      YES unset  administratively down down
GigabitEthernet6/17    unassigned      YES unset  administratively down down
GigabitEthernet6/18    unassigned      YES unset  administratively down down
GigabitEthernet6/19    unassigned      YES unset  administratively down down
GigabitEthernet6/20    unassigned      YES unset  administratively down down
GigabitEthernet6/21    unassigned      YES unset  administratively down down
GigabitEthernet6/22    unassigned      YES unset  administratively down down
GigabitEthernet6/23    unassigned      YES unset  administratively down down
GigabitEthernet6/24    unassigned      YES unset  administratively down down
GigabitEthernet6/25    unassigned      YES unset  administratively down down
GigabitEthernet6/26    unassigned      YES unset  administratively down down
GigabitEthernet6/27    unassigned      YES unset  administratively down down
GigabitEthernet6/28    unassigned      YES unset  administratively down down
GigabitEthernet6/29    unassigned      YES unset  administratively down down
GigabitEthernet6/30    unassigned      YES unset  administratively down down
GigabitEthernet6/31    unassigned      YES unset  administratively down down
GigabitEthernet6/32    unassigned      YES unset  administratively down down
GigabitEthernet6/33    unassigned      YES unset  administratively down down
GigabitEthernet6/34    unassigned      YES unset  administratively down down
GigabitEthernet6/35    unassigned      YES unset  administratively down down
GigabitEthernet6/36    unassigned      YES unset  administratively down down
GigabitEthernet6/37    unassigned      YES unset  administratively down down
GigabitEthernet6/38    unassigned      YES unset  administratively down down
GigabitEthernet6/39    unassigned      YES unset  administratively down down
GigabitEthernet6/40    unassigned      YES unset  administratively down down
GigabitEthernet6/41    unassigned      YES unset  administratively down down
GigabitEthernet6/42    unassigned      YES unset  administratively down down
GigabitEthernet6/43    unassigned      YES unset  administratively down down
GigabitEthernet6/44    unassigned      YES unset  administratively down down
GigabitEthernet6/45    unassigned      YES unset  administratively down down
GigabitEthernet6/46    unassigned      YES unset  administratively down down
GigabitEthernet6/47    unassigned      YES unset  administratively down down
GigabitEthernet6/48    unassigned      YES unset  administratively down down
GigabitEthernet7/1     unassigned      YES unset  up                    up
GigabitEthernet7/2     unassigned      YES unset  up                    up
GigabitEthernet7/3     unassigned      YES unset  up                    up
GigabitEthernet7/4     unassigned      YES unset  up                    up
GigabitEthernet7/5     unassigned      YES unset  up                    up
GigabitEthernet7/6     unassigned      YES unset  up                    up
GigabitEthernet7/7     unassigned      YES unset  up                    up
GigabitEthernet7/8     unassigned      YES unset  up                    up
GigabitEthernet7/9     unassigned      YES unset  down                  down
GigabitEthernet7/10    unassigned      YES unset  down                  down
GigabitEthernet7/11    unassigned      YES unset  down                  down
GigabitEthernet7/12    unassigned      YES unset  down                  down
GigabitEthernet7/13    unassigned      YES unset  down                  down
GigabitEthernet7/14    unassigned      YES unset  down                  down
GigabitEthernet7/15    unassigned      YES unset  down                  down
GigabitEthernet7/16    unassigned      YES unset  down                  down
GigabitEthernet7/17    unassigned      YES unset  down                  down
GigabitEthernet7/18    unassigned      YES unset  up                    up
GigabitEthernet7/19    unassigned      YES unset  up                    up
GigabitEthernet7/20    unassigned      YES unset  up                    up
GigabitEthernet7/21    unassigned      YES unset  up                    up
GigabitEthernet7/22    unassigned      YES unset  up                    up
GigabitEthernet7/23    unassigned      YES unset  up                    up
GigabitEthernet7/24    unassigned      YES unset  up                    up
7 Replies 7
devils_advocate
Level 7
Level 7
You are missing a default route on the switch.
Although you have assigned Vlan 1 an IP address of 204.49.178.6, you have not configured a default route.
I can see an 'ip default-gateway' statement but this is not a default route.
Add the following:
ip route 0.0.0.0 0.0.0.0 204.49.178.1
The ip default-gateway command simply provides the switch itself with a default gateway in terms of management.
Bear in mind that you are also not going any form of NAT on this switch so the packets are going to hit the public address without being translated.
Router:
ValpMgt#sho run
version 12.4
hostname ValpMgt
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip cef
   import all
ip ssh version 2
 description WAN
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 description LAN
 no ip address
 ip nat inside
 duplex auto
 speed auto
 ip nat inside
no ip http server
control-plane
line con 0
 password valPower
 login
line aux 0
line vty 0 4
 login local
 transport input ssh
end
NVI0
Switch:
valp01#sho run
version 12.2
no service pad
hostname valp01
boot-start-marker
boot-end-marker
redundancy
 mode sso
no aaa new-model
ip subnet-zero
ip ssh version 2
no file verify auto
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
 shutdown
interface Vlan1
 no ip address
 shutdown
interface Vlan10
interface Vlan11
 no ip address
interface Vlan20
interface Vlan21
interface Vlan22
interface Vlan23
ip http server
ip pim ssm default
line con 0
 logging synchronous
 login
 stopbits 1
line vty 0 4
 logging synchronous
 login local
line vty 5 15
 logging synchronous
 login local
end
It's not clear where the 4948 comes into it now you are using a 2811 router ?
it also not clear why you are trunking to the router ie. you should really be routing the vlans on the 4507.
And the public IP on the 2811 is not the same range as used on the 4948.
Finally, for the moment, it's not clear whether you are pinging from the switch or from a client in one of the vlans.
Can you clear up the confusion ie. describe exactly how you have it connected up, what exactly you want to achieve and where the 4948 comes into it.
Jon
Ok. Sorry about the confusion. Forget the 4948. I added the cable modem and 2811.
Cable Modem>2811>4507
From the 4507 i can ping 172.16.110.4, which is the fa0/1 of the 2811. I cannot ping fa0/0.
From the 2811 i can ping the world.
I also posted an updated config. I'll repost the important configs.
Router:
ValpMgt#sho run
version 12.4
hostname ValpMgt
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
ip cef
   import all
ip ssh version 2
 description WAN
 ip address dhcp
 ip nat outside
 duplex auto
 speed auto
 description LAN
 no ip address
 ip nat inside
 duplex auto
 speed auto
 ip nat inside
no ip http server
control-plane
line con 0
 password *******
 login
line aux 0
line vty 0 4
 login local
 transport input ssh
end
Switch:
valp01#sho run
Current configuration : 17229 bytes
version 12.2
no service pad
hostname valp01
boot-start-marker
boot-end-marker
redundancy
 mode sso
no aaa new-model
ip subnet-zero
ip ssh version 2
no file verify auto
interface Vlan1
 no ip address
 shutdown
interface Vlan10
interface Vlan11
 no ip address
ip default-gateway 172.16.110.4
ip http server
ip pim ssm default
line con 0
 logging synchronous
 login
 stopbits 1
line vty 0 4
 logging synchronous
 login local
line vty 5 15
 logging synchronous
 login local
end
Is the switch meant to be doing any routing ?
If so can you replace the defaut gateway with a default route on the switch.
Secondly from either the switch or a client in vlan 10 can you ping an internet IP and then from the router post the output of -
"sh ip nat translations".
Jon
No the switch is just a switch. I may want it to do some routing between vlans on the switch but that is it.
You know i didnt even think to see if i could get on the net since i couldn't ping out. I am such an idiot. The internet is working great. DHCP is working too.
No problem, it easy to get fixed on something and miss the obvious, done it many times myself :-)
So is everything okay now ?
Jon
