Getting internet to work from switch
jpanzica747
I am new to working with Cisco stuff and asking questions on here, so I hope I am asking this in proper form.
I have a Linksys home router, connected to a Cisco 3825 router, connected to a Cisco 3560 switch.
The router is working well and able to ping the internet with no problem.
The switch is connected via port G0/1 on the router and f0/1 on the switch.
I cannot connect to the switch in any way from the Cisco 3825 router, however I do have VOIP working with the internet conncetion on G0/0 and phones connected to any port on the switch.
What I would like to do is connect to the switch from the router and also be able to access the internet from the switch.  I am sure I am routing something wrong but not sure how to figure out what.  Any help is super appreciated.
16 Replies 16
make the changes marked in bold. When you are done, post the full configurations of the switch and the router so we can double check everything:
Switch
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
switchport voice vlan 20
spanning-tree portfast
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,10,20,55,77
switchport mode trunk
interface Vlan1
ip address 10.10.30.248 255.255.255.0
--> no interface Vlan10
ip address 10.10.10.248 255.255.255.0
ip default-gateway 10.10.30.1
ip classless
-> no ip route 0.0.0.0 0.0.0.0 10.10.1.100
ip http server
ip http secure-server
Router
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
ip address 10.10.30.1 255.255.255.0
ip nat inside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.10
encapsulation dot1q 10
ip nat inside
duplex auto
speed auto
media-type rj45
ip nat inside source list 1 interface GigabitEthernet0/0 overload
--> no ip route 0.0.0.0 0.0.0.0 10.10.1.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
--> no access-list 1 permit any
access-list 1 permit 10.10.0.0 0.0.255.255
I think this fixed it and it is working correctly.  Thank you for your help it is very appreciated.
