Getting NAT Translations but no internet
Alkemyst1971
This is my router config:
interface GigabitEthernet0/0.168
description Security Desk
encapsulation dot1Q 168
ip address 192.168.0.1 255.255.255.0
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly in
ip nat inside source route-map SECURITY_DESK interface GigabitEthernet0/0.168 overload
route-map SECURITY_DESK permit 10
match ip address 168
ip route 192.168.0.0 255.255.255.0 PUBLIC_IP
access-list 168 permit ip 192.168.0.0 0.0.0.255 any
It's building translations, but somehow the traffic is not leaving the router for the internet.  What am I doing wrong?
EDIT:  I notice I am getting a 192.168.0.1 address for my inside global instead of a public IP.  Not sure why that is happening.
8 Replies 8
You need to use
Ip nat outside
Not
Ip nat inside
Under this interface
MHM
Thanks, but I caught was I did.  The inside interface is correct, however; I needed to nat back to my outside interface.
I dont get your comment
It mandatory to use
Ip nat outside
Under interface use for NAT overload
MHM
My full config:
ip flow ingress
ip flow egress
ip nat inside
interface GigabitEthernet0/2.423
description Causeway Sec_desk Handoff
encapsulation dot1Q 423
no ip vrf forwarding verity-1001
ip address PUBLIC_IP.262 255.255.255.252
ip nat outside
ip nat inside source route-map SECURITY_DESK interface GigabitEthernet0/2.423 overload
ip route 192.168.0.0 255.255.255.0 PUBLIC_IP.161
ip route 0.0.0.0 0.0.0.0 PUBLIC_IP.161
This need
MHM
default route is a different circuit.  It's all working now.
Glad your issue solved
Have a nice day
MHM
Hello
Example base on your OP:
int x.x
no shut
int x.x.168
description  WAN
ip address 1.1.1.1 255.255.255.252
ip nat outside
int x.x
description  LAN
ip nat inside
ip access-list extended 168
route-map LAN
ip nat inside source route-map LAN interface <WAN> overload
ip route 0.0.0.0 0.0.0.0 <WAN interface> 1.1.1.2
Kind Regards
Paul
