Getting warning IP nat pool too small
S Kumar
I want to NAT single inside IP to multiple outbound IP's based up on the destination subnet. For example :
My appserver should be natted to 10.10.1.10 for packets tx/rx toward customer1
My appserver should be natted to 10.10.2.10 for packets tx/rx toward customer2
My appserver should be natted to 10.10.3.10 for packets tx/rx toward customer3.
I have a router Cisco1921 with Gi0/1 configured with
 ip 192.168.1.1
I have an app server with IP address 192.168.1.10 and gateway 192.168.1.1
I have three customers connected to us using three private point to point circuits.
All the three circuits are connected to my layer 2 Ethernet switch C2960.
On Ethernet switch customer1 is in VLAN 10, customer 2 is in VLAN 20 and customer3 is on VLAN 30.
Cisco router 1921 Gi0/0 has three sub interfaces, one for each customer.I was thinking that I wll create three
ACL
and
NAT POOL
for each customer and use the
ACL
to assign the
seperate pool for each customer. I hit a road block,
ip NAT pool
gives me a warning when I try to create a pool with single ip it is asking for atleast netmask .252 and giving the following warning
Pool NAT-POOL-CUST3 mask 255.255.255.255 too small; should be at least 255.255.255.252
How can I NAT my single inside IP to multiple outbound IP's based upon the destination subnet?
interface GigabitEthernet0/1
description LOCAL INTERFACE
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/0.10
description CUSTOMER1
encapsulation dot1Q 10
ip address 172.16.10.1 255.255.255.252
ip nat outside
interface GigabitEthernet0/0.20
description CUSTOMER2
encapsulation dot1Q 20
ip address 172.16.20.1 255.255.255.252
ip nat outside
interface GigabitEthernet0/0.30
description CUSTOMER3
encapsulation dot1Q 30
ip address 172.16.30.1 255.255.255.252
ip nat outside
ip route 172.16.101.0 255.255.255.0 172.16.10.2
ip route 172.16.102.0 255.255.255.0 172.16.20.2
ip route 172.16.103.0 255.255.255.0 172.16.30.2
ip access-list extended ACL-NAT-CUST1
permit ip host 192.168.1.10 172.16.101.0 0.0.0.255
ip access-list extended ACL-NAT-CUST2
permit ip host 192.168.1.10 172.16.102.0 0.0.0.255
ip access-list extended ACL-NAT-CUST3
permit ip host 192.168.1.10 172.16.103.0 0.0.0.255
ip nat pool NAT-POOL-CUST1 10.10.1.10 10.10.1.10 netmask 255.255.255.255
ip nat pool NAT-POOL-CUST2 10.10.2.10 10.10.2.10 netmask 255.255.255.255
ip nat pool NAT-POOL-CUST3 10.10.3.10 10.10.3.10 netmask 255.255.255.255
##I get the warning got the above three commands##
If I get past the warning then I was planning to use the following:
ip nat outside source list ACL-CUST1 pool NAT-POOL-CUST1 add-route
ip nat outside source list ACL-CUST2 pool NAT-POOL-CUST2 add-route
ip nat outside source list ACL-CUST3 pool NAT-POOL-CUST3 add-route
19 Replies 19
VPN traffic must not
NATing
VPN must override
NAT
Could you please elaborate? What are my options if I have to use
NAT
with IPSEC?
I have done
natting
on vpn traffic various times, my experience is more on
ASA
. This is the first time, I have to deal with this stuff on a router.
good luck
I think it should work.  Depends on inside/outside direction but assuming it's inside -> outside then the crypto map ACL should match the IP after NAT I believe.  But as always - test to confirm.
https://www.cisco.com/c/en/us/support/docs/ip/network-address-translation-nat/6209-5.html
ps. also never had trouble with sending NATed packets up VPN.
Rich,
Appreciate your response, I had already gone through the article you posted but I could not comprehend it. I changed the access list to post-
NAT IP
in my lab setup and it worked.
