GGSN: real APN selection using Radius
MCentrick2010
We are trying to setup the virtual APN with "pre-authentication" feature on GGSN Release 9, whereas the Radius server changes the APN during the authentication stage.
The question is which Radius attribute in the Access-Accept should contain the new APN, as the documentation is too generic:
"The target APN is returned as a Radius attribute in the Access-Accept message to the GGSN".
We have tried to use "Called-station-ID" which is the attribute that carries the incoming APN (virtual APN).
ckoester
Try Cisco-AVPair = "gprs:apn=" :-)
ckoester
Thanks Carsten.
I really appreciate it. Our customer is not getting timely support on this. Will test it soon.
It works!!
