Gi2/32 suspended: LACP currently not enabled on the remote port
prashantrecon
On site2  end switch has IOS
c3750e-universalk9-mz.122-55.SE1
Below is the error
*Mar  8 00:53:19.730: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
*Mar  8 00:53:19.873: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state UP
*Mar  8 00:53:20.905: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  8 00:53:21.911: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state UP
*Mar  8 00:53:22.918: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  8 00:53:23.925: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state UP
*Mar  8 00:53:24.856: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN
*Mar  8 00:53:24.864: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
*Mar  8 00:53:26.777: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN
*Mar  8 00:53:27.775: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
*Mar  8 00:53:28.790: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN
*Mar  8 00:53:29.788: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state UP
*Mar  8 00:53:29.998: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Mar  8 00:53:30.812: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 2 has changed to state DOWN
MUMBAISW1#  show clock
*00:53:39.863 UTC Mon Mar 8 1993
on site 1 error is
For  config Please find the attachement
11 Replies 11
prashantrecon
Is the config correct  or not ?
Hi Prashant,
Your doc doesn't contain config only outputs are there.
Can you list your Etherchannel configs;
site 1
interface Port-channel77
ip address 192.168.2.52 255.255.255.0
end
interface GigabitEthernet1/32
description "tata point to point etherchannel"
no ip address
channel-protocol lacp
channel-group 77 mode active
end
interface GigabitEthernet2/32
no ip address
shutdown
flowcontrol send off
site2
interface Port-channel47
no switchport
ip address 192.168.2.51 255.255.255.0
end
interface GigabitEthernet1/0/39
no switchport
no ip address
channel-group 47 mode active
end
interface GigabitEthernet2/0/39
no switchport
no ip address
Hi Prashant,
this error you are receiving concerns the StackWise ports, not etherchannel link. it is the connection between switch 1 and 2 in the stack, check the physical connection, cable, stack interface.
on Site 1: issue no switchport on the interfaces and no shut ur interface then.
shut / no shut the portchannel 77 and 47 then.
Hope it Helps,
Soroush.
Hope it Helps!
Soroush.
Thanks for the reply
Still it is not working
As two isp are diffrenet is there any setting needs to be done fro there side.
Is there any problem of bundling ?
hmm... i dont follow you, you are actually trying to make an etherchannel between two distant sites, which are connected through two ISP's?
sorry but if your network spans over two ISPs, I dont think it is possible. with one service provider invovled you could used dot1q tunneling (Q-in-Q) to form an etherchannel between remote sites and thats only if the ISP supports 802.1q QinQ.
> yes the ISP should do settings to support dot1q tunneling
HTH,
Soroush.
Hope it Helps!
Soroush.
Thanks a lot
Will co-ordinate with isp and let u know
remove flowcontrol send off on port 2/32
Paul George
Hi Guys,
I have the solution to this problem.
The reason why we get the message "LACP currently no enabled on the remote port " is because LACP is not enabled on the member ports.
While creating the Port channel the members are not in the switch port mode .
By enabling the interface with switch port command can change the status from suspended to connected :)
PAUL
Hi Guys,
Mr. PAUL is right and here is the configuration example are given
and now i think problem solved.
Mahbub
Ahmed Mostafa
Recently i faced this issue and you can check 1 of the below :
1- the 2 uplinks configured correctly under channel group command
2- or you forgot to add native vlan .
Ahmed
