GigabitEthernet changed state randomly
George.Pettrov
I am having some issues with port configuration port (cisco 2960x) of  Gigaset DECT Manager integrated in Cisco Call Manager.
The state of the configured port randomly changes and the communication between DECT headsets stops. After restart all goes ok. This is the log file:
Nov 9 09:25:32.290: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: Entry
Nov 9 09:25:32.290: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: timers not running
Nov 9 09:25:32.290: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: starting lineproto timer
Nov 9 09:25:32.290: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: delay 1000
Nov 9 09:25:32.290: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: Exit
Nov 9 09:25:33.294: [IDB Gi1/0/17 DURUYY] LSTATE_TMR: Entry
Nov 9 09:25:33.294: [IDB Gi1/0/17 DURUYY] LSTATE_TMR: not spoofing, current state: n
Nov 9 09:25:33.294: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to down
Nov 9 09:25:33.294: [IDB Gi1/0/17 DURUYY] LSTATE_TMR: Exit
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUYY] CSTATE_TMR: Entry
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUYY] CSTATE_TMR: netidb=Gi1/0/17, linestate: n
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUYY] LSTATE_REQ: Entry
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUYY] LSTATE_REQ: timers not running
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUYY] LSTATE_REQ: Exit
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUYY] CSTATE_TMR: transition detected
Nov 9 09:25:34.293: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17, changed state to down
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUnY] TRANS_ADJ: Entry
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUnn] TRANS_ADJ: propagating change to subifs
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUnn] TRANS_ADJ: Exit
Nov 9 09:25:34.293: [IDB Gi1/0/17 DURUnn] CSTATE_TMR: Exit
Nov 9 09:25:46.813: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Entry
Nov 9 09:25:46.813: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Exit
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] CSTATE_TMR: Entry
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] CSTATE_TMR: netidb=Gi1/0/17, linestate: Y
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Entry
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: timers not running
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: starting lineproto timer
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: delay 1000
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Exit
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUnn] CSTATE_TMR: transition detected
Nov 9 09:25:48.806: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17, changed state to up
Nov 9 09:25:48.806: [IDB Gi1/0/17 UDRUYn] TRANS_ADJ: Entry
Nov 9 09:25:48.809: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: propagating change to subifs
Nov 9 09:25:48.809: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Exit
Nov 9 09:25:48.809: [IDB Gi1/0/17 UDRUYY] CSTATE_TMR: Exit
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: Entry
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: not spoofing, current state: Y
Nov 9 09:25:49.809: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to up
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: informing line state transitions
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Entry
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Exit
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] ROUTE_ADJ: Entry
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] ROUTE_ADJ: Exit
Nov 9 09:25:49.809: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: Exit
Nov 9 09:26:16.823: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 80
And this is the configuration of the port of all - Gigaset Manager and Gigaset Cells:
interface GigabitEthernet1/0/17
description ### DECT Manager Gigaset N720 DM Pro ###
switchport access vlan 80
switchport mode access
no mdix auto
Any help would be very welcome!
Thank you in advance!
16 Replies 16
Hi, Can you try to force speed and duplex on both devices?
Regards.
You mean
duplex full
speed 100 (the interface of the dect specification is 10/100 Mbps)
pp. We have 10 Dect Cells and 1 Dect manager attached to different 2960x switches all with the same conf.
Yes, exactly.
Try to fix speed and duplex and check if the flapping stop.
Regards.
Thank you for the immediate response! I changed the configuration and will keep you informed!
BR
Hello
Has mdix been turned off or was that the default?
Int gig x/x
mdix auto
spanning-tree portfast
Kind Regards
Paul
The conf. used to be. :
no mdix auto
Not it is:
duplex full
speed 100
no mdix auto
BR,
Georgi Petrov
Hello
Suggest
duplex auto
speed auto
mdix auto
Kind Regards
Paul
I will try this one for sure. Thank you!
But let first check if speed 100 and duplex full will resolve the issue.
I will keep you informed>
BR,
Georgi Petrov
Still the same situation:
3.867: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: propagating change to subifs
Nov 22 10:42:53.867: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Exit
Nov 22 10:42:53.867: [IDB Gi1/0/17 UDRUYY] CSTATE_TMR: Exit
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: Entry
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: not spoofing, current state: Y
Nov 22 10:42:54.866: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to up
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: informing line state transitions
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Entry
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Exit
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] ROUTE_ADJ: Entry
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] ROUTE_ADJ: Exit
Nov 22 10:42:54.866: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: Exit
Nov 22 10:43:21.874: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 80
Nov 22 14:53:21.613: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: Entry
Nov 22 14:53:21.613: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: timers not running
Nov 22 14:53:21.613: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: starting lineproto timer
Nov 22 14:53:21.613: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: delay 1000
Nov 22 14:53:21.613: [IDB Gi1/0/17 UDRUYY] LSTATE_REQ: Exit
Nov 22 14:53:22.613: [IDB Gi1/0/17 DURUYY] LSTATE_TMR: Entry
Nov 22 14:53:22.613: [IDB Gi1/0/17 DURUYY] LSTATE_TMR: not spoofing, current state: n
Nov 22 14:53:22.613: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to down
Nov 22 14:53:22.613: [IDB Gi1/0/17 DURUYY] LSTATE_TMR: Exit
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUYY] CSTATE_TMR: Entry
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUYY] CSTATE_TMR: netidb=Gi1/0/17, linestate: n
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUYY] LSTATE_REQ: Entry
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUYY] LSTATE_REQ: timers not running
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUYY] LSTATE_REQ: Exit
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUYY] CSTATE_TMR: transition detected
Nov 22 14:53:23.619: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17, changed state to down
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUnY] TRANS_ADJ: Entry
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUnn] TRANS_ADJ: propagating change to subifs
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUnn] TRANS_ADJ: Exit
Nov 22 14:53:23.619: [IDB Gi1/0/17 DURUnn] CSTATE_TMR: Exit
Nov 22 14:53:35.374: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Entry
Nov 22 14:53:35.374: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Exit
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] CSTATE_TMR: Entry
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] CSTATE_TMR: netidb=Gi1/0/17, linestate: Y
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Entry
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: timers not running
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: starting lineproto timer
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: delay 1000
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] LSTATE_REQ: Exit
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUnn] CSTATE_TMR: transition detected
Nov 22 14:53:37.370: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/17, changed state to up
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUYn] TRANS_ADJ: Entry
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: propagating change to subifs
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Exit
Nov 22 14:53:37.370: [IDB Gi1/0/17 UDRUYY] CSTATE_TMR: Exit
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: Entry
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: not spoofing, current state: Y
Nov 22 14:53:38.369: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/17, changed state to up
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: informing line state transitions
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Entry
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] TRANS_ADJ: Exit
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] ROUTE_ADJ: Entry
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] ROUTE_ADJ: Exit
Nov 22 14:53:38.369: [IDB Gi1/0/17 UDRUYY] LSTATE_TMR: Exit
Nov 22 14:54:05.377: %SPANTREE-5-TOPOTRAP: Topology Change Trap for vlan 80
I will try what Paul suggested:
duplex auto
speed auto
mdix auto
Can you check the DECT cell logs?
Could be a restart of the DECT cell? I had a similar issue in the past due to a provisioning of some devices.
During provisioning (randomly in a day) the devices rebooted itself.
Regards.
Yes, I can restart every single cell and the manager itself.
Actually i tried to activate logs and i did not make it. Any idea?
Hello All,
I confirm - this is DECT provisioning. But now, after I changed the configuration - the system restarts and gets back to a normal state, which i believe is normal. Thank you all for your support!
BR,
George Pettrov
Hello
BR,
George Pettrov
What configuration did you change?
Kind Regards
Paul
duplex full
speed 100
no mdix auto
BR
